vin question, two number plates missing |
drifter914 |
Jun 29 2019, 05:27 PM
drifter914 Group: Members Posts: 50 Joined: 12-May 13 From: pearce, arizona 85625 Member No.: 15,863 Region Association: Southwest Region |
Hi Guys... I bought a '74 914 with Indiana title showing the same vin as on the windshield frame tag & the tag riveted to passenger side front wheelwell. Both of these tags are easily replaceable.
The vin sticker inside driver door jamb is missing & the number stamped on top of pass. wheelwell has been ground off ... gone ! The number stamped inside rear trunk floor on pass. side is a different number & is only 7 digits. Should this number be the same as vin ? So... so do I have a vin swap situation here... ? I can understand maybe removing the sticker inside the driver door jamb for a repaint, but to grind off the number stamped into the metal on top of front pass. wheelwell seems very intentional & for what purpose ? Is the number stamped inside rear trunk floor supposed to match vin on title ? Not completely sure what I have here... possible vin swap ? I feel the number in rear trunk floor may be key to solution. (IMG:style_emoticons/default/confused24.gif) What say you ... Thanks... Terry in Az |
pgollender |
Jul 3 2019, 12:02 AM
Member Group: Members Posts: 193 Joined: 5-July 11 From: Sacramento Member No.: 13,281 Region Association: Northern California |
Drifter, if fender is original, the stamped VIN numbers will appear in mirror order on the INSIDE of the fender well. Use a small amount of paint remover and nylon scrub brush, and then use some aluminum foil and trace the hell out of it with your finger. It may take several tries to get a nice tracing. That is how I recovered by VIN.
SirAndy |
Jul 3 2019, 12:20 PM
Resident German Group: Admin Posts: 41,669 Joined: 21-January 03 From: Oakland, Kalifornia Member No.: 179 Region Association: Northern California |
Drifter, if fender is original, the stamped VIN numbers will appear in mirror order on the INSIDE of the fender well. Use a small amount of paint remover and nylon scrub brush, and then use some aluminum foil and trace the hell out of it with your finger. It may take several tries to get a nice tracing. That is how I recovered by VIN. Interesting ... (IMG:style_emoticons/default/idea.gif) |
Lo-Fi Version | Time is now: 1st June 2024 - 01:58 AM |
