| sjhenry1075 |
Apr 18 2018, 09:21 AM
Member ![]() ![]() Group: Members Posts: 270 Joined: 22-July 12 From: Stevensville, MD Member No.: 14,709 Region Association: North East States
So I have a dumb question, but as my wife (who is a teacher) always says, the only dumb question is the question not asked so here goes..
I recently replaced the fuel lines in my 71 with stainless and new braided hose in the engine compartment. My question is, the lines that I purchased from Pelican, the smaller ones, which I believe would be the return lines, would not fit over any of the fittings so I just used the larger line. Does it matter if I use the larger braided hose for both supply and return? Thank you in advance for being patient and providing answers to my questions.. |
| jcd914 |
Jul 1 2019, 12:41 PM
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,096 Joined: 7-February 08 From: Sacramento, CA Member No.: 8,684 Region Association: Northern California |
(IMG:style_emoticons/default/agree.gif) Chris has everything you need including injector elbows.
When I redid my fuel hoses I was impatient and just went to the Oreilly's Auto Parts by my house and bought some Gates FI Hose with SAE Spec 30R14-2. You need 30R9 or higher, the 30R14 handles the current fuel but the are 2 version of the Gates hose. The -1 version is low pressure nit for FI, only 50PSI rating, this is what they brought out first to sell me. The -2 version is rated at 225PSI which is what I used on my car. I had to explain to them there were specs for fuel hose. The AutoZone by me only had 30R7 spec hose and didn't know what it meant. Jim |
| Mark Henry |
Jul 1 2019, 01:05 PM
that's what I do! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 20,065 Joined: 27-December 02 From: Port Hope, Ontario Member No.: 26 Region Association: Canada |
(IMG:style_emoticons/default/agree.gif) Chris has everything you need including injector elbows. When I redid my fuel hoses I was impatient and just went to the Oreilly's Auto Parts by my house and bought some Gates FI Hose with SAE Spec 30R14-2. You need 30R9 or higher, the 30R14 handles the current fuel but the are 2 version of the Gates hose. The -1 version is low pressure nit for FI, only 50PSI rating, this is what they brought out first to sell me. The -2 version is rated at 225PSI which is what I used on my car. I had to explain to them there were specs for fuel hose. The AutoZone by me only had 30R7 spec hose and didn't know what it meant. Jim 30R7 is low pressure hose, technically it can be used on the low pressure sections of a FI system but it's only a few 6" sections so I stick with the 30R9. After reading the technical data I use 30R9 even with carbs. All braided hose I've used becomes brittle and obvious cracking can be seen on the cut (clamp) end of the hose in as little as 12-18 months. It's OK for smog/vacuum lines but I refuse to use it for fuel. |
| bbrock |
Jul 1 2019, 10:41 PM
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 5,269 Joined: 17-February 17 From: Montana Member No.: 20,845 Region Association: Rocky Mountains
(IMG:style_emoticons/default/agree.gif) Chris has everything you need including injector elbows. When I redid my fuel hoses I was impatient and just went to the Oreilly's Auto Parts by my house and bought some Gates FI Hose with SAE Spec 30R14-2. You need 30R9 or higher, the 30R14 handles the current fuel but the are 2 version of the Gates hose. The -1 version is low pressure nit for FI, only 50PSI rating, this is what they brought out first to sell me. The -2 version is rated at 225PSI which is what I used on my car. I had to explain to them there were specs for fuel hose. The AutoZone by me only had 30R7 spec hose and didn't know what it meant. Jim 30R7 is low pressure hose, technically it can be used on the low pressure sections of a FI system but it's only a few 6" sections so I stick with the 30R9. After reading the technical data I use 30R9 even with carbs. All braided hose I've used becomes brittle and obvious cracking can be seen on the cut (clamp) end of the hose in as little as 12-18 months. It's OK for smog/vacuum lines but I refuse to use it for fuel. Belmetric sells German braided 30R7 hose in a variety of sizes https://www.belmetric.com/multifuel-hoseeth...roved-c-14_662/ I'm going to try it for vacuum and vent hoses. |
| Mark Henry |
Jul 3 2019, 12:45 PM
(IMG:style_emoticons/default/agree.gif) Chris has everything you need including injector elbows. When I redid my fuel hoses I was impatient and just went to the Oreilly's Auto Parts by my house and bought some Gates FI Hose with SAE Spec 30R14-2. You need 30R9 or higher, the 30R14 handles the current fuel but the are 2 version of the Gates hose. The -1 version is low pressure nit for FI, only 50PSI rating, this is what they brought out first to sell me. The -2 version is rated at 225PSI which is what I used on my car. I had to explain to them there were specs for fuel hose. The AutoZone by me only had 30R7 spec hose and didn't know what it meant. Jim 30R7 is low pressure hose, technically it can be used on the low pressure sections of a FI system but it's only a few 6" sections so I stick with the 30R9. After reading the technical data I use 30R9 even with carbs. All braided hose I've used becomes brittle and obvious cracking can be seen on the cut (clamp) end of the hose in as little as 12-18 months. It's OK for smog/vacuum lines but I refuse to use it for fuel. Belmetric sells German braided 30R7 hose in a variety of sizes https://www.belmetric.com/multifuel-hoseeth...roved-c-14_662/ I'm going to try it for vacuum and vent hoses. 30R7 is low pressure carb hose, I know you said you're using it for smog hose, just clarifying you ca't use it for FI. |
| bbrock |
Jul 3 2019, 03:08 PM
(IMG:style_emoticons/default/agree.gif) Chris has everything you need including injector elbows. When I redid my fuel hoses I was impatient and just went to the Oreilly's Auto Parts by my house and bought some Gates FI Hose with SAE Spec 30R14-2. You need 30R9 or higher, the 30R14 handles the current fuel but the are 2 version of the Gates hose. The -1 version is low pressure nit for FI, only 50PSI rating, this is what they brought out first to sell me. The -2 version is rated at 225PSI which is what I used on my car. I had to explain to them there were specs for fuel hose. The AutoZone by me only had 30R7 spec hose and didn't know what it meant. Jim 30R7 is low pressure hose, technically it can be used on the low pressure sections of a FI system but it's only a few 6" sections so I stick with the 30R9. After reading the technical data I use 30R9 even with carbs. All braided hose I've used becomes brittle and obvious cracking can be seen on the cut (clamp) end of the hose in as little as 12-18 months. It's OK for smog/vacuum lines but I refuse to use it for fuel. Belmetric sells German braided 30R7 hose in a variety of sizes https://www.belmetric.com/multifuel-hoseeth...roved-c-14_662/ I'm going to try it for vacuum and vent hoses. 30R7 is low pressure carb hose, I know you said you're using it for smog hose, just clarifying you ca't use it for FI. (IMG:style_emoticons/default/thumb3d.gif) Yep, I should have added that and well worth repeating. I'm mainly curious to see if they will work for vacuum/vent without getting brittle quickly. I'll be running carbs, but like you, I'm going to run 30R14 anyway. Main reason is because I might switch back to FI some day and don't want to have to switch out hose again, but I like the extra safety margin too. |
sjhenry1075 Dumb Question Apr 18 2018, 09:21 AM
76-914 Won't matter unless you get them crossed. :be... Apr 18 2018, 09:25 AM
Won't matter unless you get them crossed. :b... Apr 18 2018, 09:34 AM
sjhenry1075
Won't matter unless you get them crossed. :... Apr 18 2018, 09:37 AM
Amphicar770 Should be fine. The bigger concern should be if t... Apr 18 2018, 09:31 AM
sjhenry1075
Should be fine. The bigger concern should be if ... Apr 18 2018, 09:36 AM
Amphicar770
[quote name='Amphicar770' post='2600512' date='Ap... Apr 18 2018, 09:54 AM
The Cabinetmaker I am unaware of any ethanol rated braided line. I ... Apr 18 2018, 01:42 PM
sjhenry1075
I am unaware of any ethanol rated braided line. I... Apr 19 2018, 01:10 PM
Jonathan Livesay
I am unaware of any ethanol rated braided line. I... Apr 19 2018, 01:28 PM
Chris914n6 Depending on year, it's either 2 same size lin... Apr 18 2018, 03:11 PM
jcd914 I don't know the rating of the fuel lines you ... Apr 19 2018, 01:24 PM
sjhenry1075
I don't know the rating of the fuel lines you... Apr 19 2018, 01:35 PM
sjhenry1075 Well you were right, the braided lines seeped fuel... Jul 1 2019, 11:08 AM
ChrisFoley Tangerine Racing Products Jul 1 2019, 11:20 AM
JawjaPorsche Contact Tangerine Racing. Explain what you have a... Jul 1 2019, 01:53 PM
JeffBowlsby 7mm ID for the engine bay fuel hose. The original... Jul 1 2019, 02:07 PM
ChrisFoley
7mm ID for the engine bay fuel hose. The origina... Jul 1 2019, 02:55 PM
VaccaRabite Fires suck. Get that braided crap off your car. ... Jul 1 2019, 02:36 PM
sjhenry1075 Thank you for your replies everyone. I will be rem... Jul 3 2019, 09:25 AM
ChrisFoley
Does it matter if I use the larger [braided] hos... Jul 3 2019, 10:11 AM
sjhenry1075
Does it matter if I use the larger [braided] ho... Jul 3 2019, 10:28 AM
ChrisFoley Ships today.
:) Jul 3 2019, 10:32 AM
sjhenry1075
Ships today.
Thank you Chris! Jul 3 2019, 10:51 AM![]() ![]() |
Lo-Fi Version | Time is now: 2nd April 2026 - 05:26 PM |
