| larss |
Jul 9 2019, 01:30 PM
Member ![]() ![]() Group: Members Posts: 434 Joined: 10-September 09 From: Sweden Member No.: 10,787 Region Association: Scandinavia |
Have some problems with a stock 1,7 D-jet that runs wery lean, hunts and pops in the intake, hardly running at all....reving up wery uneven and slowly.
-Engine has not been running for severeal years so there is no history to tell. -Timing triple checked 27 degrees at 3500rpm -Fuel pressure triple checked 31psi -All 4 injectors new (repro) -Trigger points checked OK -Changed to anoter MPS (which runs well in another d-jet) with no difference -Changed head temp sensor with no difference -Compression tested, even around 145psi -Points, condenser, cap, cables are new (also tested with an old set but no difference) -All injectors getting pulses, checked and injector plugs are at the correct injectors -Yes firing order is triple checked The only way to get it running quite OK is to replace the head temp sensor with a potentiometer at 3Kohms, runs quite good with that even when warm. This leads me to think that it is running w e r y lean for some reason. Any ideas? /Lars S |
JeffBowlsby Which MPS part number do you have, does it hold va... Jul 9 2019, 01:32 PM
larss
Which MPS part number do you have, does it hold v... Jul 9 2019, 10:51 PM
BillC Have you checked for a vacuum leak (or leaks)? Si... Jul 10 2019, 10:21 AM
larss
Have you checked for a vacuum leak (or leaks)? S... Jul 10 2019, 10:45 AM
larss Short work on the engine today again...
Found out ... Jul 11 2019, 08:57 AM
JeffBowlsby Besides the lean condition, are your distributor w... Jul 11 2019, 09:32 AM
larss
Besides the lean condition, are your distributor ... Jul 11 2019, 09:50 AM
JeffBowlsby I was not asking about your ignition timing settin... Jul 11 2019, 10:07 AM
larss
I was not asking about your ignition timing setti... Jul 11 2019, 10:27 AM
larss A late update on this....wow finally the car is ru... Aug 25 2019, 08:24 AM
larss Final update - short story:
I had a long sitting 1... Sep 16 2019, 09:37 AM![]() ![]() |
Lo-Fi Version | Time is now: 15th April 2026 - 05:23 PM |
