> Stock D-jet 1,7 running wery lean but why? S O L V E D
larss
post Jul 9 2019, 01:30 PM
Have some problems with a stock 1,7 D-jet that runs wery lean, hunts and pops in the intake, hardly running at all....reving up wery uneven and slowly.
-Engine has not been running for severeal years so there is no history to tell.
-Timing triple checked 27 degrees at 3500rpm
-Fuel pressure triple checked 31psi
-All 4 injectors new (repro)
-Trigger points checked OK
-Changed to anoter MPS (which runs well in another d-jet) with no difference
-Changed head temp sensor with no difference
-Compression tested, even around 145psi
-Points, condenser, cap, cables are new (also tested with an old set but no difference)
-All injectors getting pulses, checked and injector plugs are at the correct injectors
-Yes firing order is triple checked
The only way to get it running quite OK is to replace the head temp sensor with a potentiometer at 3Kohms, runs quite good with that even when warm.
This leads me to think that it is running w e r y lean for some reason.
Any ideas?
/Lars S
JeffBowlsby
post Jul 11 2019, 10:07 AM
I was not asking about your ignition timing settings, but are your vacuum and mechanical advance functions working? If not it may be a reason for the lag in revving.
- Lo-Fi Version Time is now: 15th April 2026 - 03:32 PM
