> Bouncing car, Car bounces when slowing down
gaocs
post Jul 13 2019, 09:27 AM
I have a really odd thing happing in my car that I hope someone can help with.
About two years ago I had new shocks fitted all round to my 1970 1.7 and since then the car has had an unusual symptom where it "bounces" up and down as you are going along... but it doesn't happen all the time. It always happens when I have been driving at say 50mph+ and then have to slow down, the car then continually bounces up and down as it's going along, especially at slow speeds. This always happens for example when I'm on a motorway and then the traffic slows right down and is then start-stop traffic. It feels like you are on a trampoline.
I always thought it was more of a "seat of the pants" feel, but today my son was driving behind me and he says you can visibly see the car bouncing up and down.
I've had the suspension checked and everything seems ok, so does anyone have any ideas as to what can be causing this? Could it be engine mounts or something else? The wheels are new as are the tyres so it's not a problem related to them not being round. The "bounce" is a few inches of movement up and down.
Thanks.
dan10101
post Jul 13 2019, 02:11 PM
TORQUE-o-holic
I never assume because one person told you that something is fine, that they are correct.
What you are describing is a shock not functioning. You can check pretty easy by pressing down hard on the 4 fenders and seeing if it bounces more than once.
Since the shocks were just worked on i suspect a shock mount or defective shock.
Without a more definite description of the bouncing it's hard go guess beyond that.
A separated or flat spotted tire can do that but it would be constant with some speeds being more noticeable that others.
What about a broken spring or torsion bar? Is one corner sagging?
Is it only when you are on the brakes or does it continue when you just coast. A warped rotor can cause a vibration under braking.
- Lo-Fi Version Time is now: 9th July 2025 - 01:13 PM
