> Gotta love the internet, Facebook group rant
IronHillRestorations
post Jul 15 2019, 09:29 PM
I. I. R. C.
The first time we had a Renegade Festival in Hot Springs (2nd mid west event), I lucked up and got a tech rep from BG Petroleum Products to give us a tech session. BG (was Wynn's Spitfire) makes fuel and oil additives. Their fuel additive is very effective for helping remove excess carbon build up. This is especially a problem in Japanese cars, or at least it was 20 years ago. He had quite a bit of technical data and, was there for a Toyota, or Honda tech summit of sorts. I saw him getting stuff out of the truck with a big BG on the side and started asking questions, and he graciously agreed to give us a tech session.
The guy did a cool "Mr. Science" kind of demonstration showing the difference between regular and premium gasoline. The demo showed that regular gas burns faster and cleaner than premium. He put a small eye dropper of each fuel on their own white Corell saucer. The regular burned without a lot of smoke and left a little residue. The premium burned slower, made noticeably more waxy like smoke, and left much more residue on the plate. Part of the point is to demonstrate that gasoline octane is the opposite of what most people think, "high test" or "the good stuff" is less volatile and has more additives. High octane fuel is the same fuel as regular, but with an additive package to lower the volatility, raising the octane for higher compression engines. He went on to say that you should use whatever your auto manufacturer recommends, and if no solid recommendation the general rule of thumb is to use the lowest octane you can, without getting pinging, or pre-ignition. Using high octane fuel in an engine that doesn't require it, can result in more unburned fuel, that can cause carbon build up in the combustion chamber, raising compression, and thereby requiring you to use a higher octane fuel that adds to the problem. Make sense? Are you tracking with me?
Most all of the guys there had questions, as well as their minds changed about the best fuel to use, in any car.
Someone posted on one of the 914 FB groups asking "what octane fuel should I use". My reply was based on my own experience, but mostly on the info from the BG rep: "Unless the mfr or engine builder says otherwise, you should run the lowest octane you can as long as you don't get pinging, or run on. Octane additives typically translate into carbon build up in the combustion chambers." Good grief, you'd have thought I said there's no Santa Claus, or our 914 is just a VW.
I've been around these cars for a while, and cringe whenever I get called an "expert" or "guru". Part of the great thing about our internet 914 community is we get to share insight and experiences both helpful and otherwise. Most everyone of us that's been elbows deep in a project has something good to share, even if it's "man I really messed up" But some people have to tell you how wrong you are, even if you aren't far off the mark, I don't get it (IMG:style_emoticons/default/blink.gif)
Chi-town
post Jul 16 2019, 05:57 PM
Combustion chamber design, spark plugs location, intake runner design, spark timing, spark length, etc.
All of these things come into play with combustion, detonation, and all the wonderful things that happen in our motors.
Saying "you should always run the lowest octane possible" is just a dumb statement without knowing the specifics of an engine or tuning done to it even on a basic production vehicle.
Modern cars are always advancing ignition till knock occurs and then making corrections to achieve optimum performance. This is a constant process and the ECU is always learning.
In an older static timing setup like a 914, your timing can only be advanced as far as the fuel will support. Hence why putting in 100 octane in a car tuned for 91 will usually net you no gain and may actually cost you power.
Then there's additive packages and oxygenation of fuel and what they do to burn rates and deposit buildup.
There's far too many variables to make blanket statements like he did
bbrock
post Jul 16 2019, 07:04 PM
QUOTE(Chi-town @ Jul 16 2019, 05:57 PM) *
Is there an example of when running higher octane than is needed to prevent pinging for that particular engine would be advantageous? I thought the sole purpose of octane was to retard detonation for the purpose of controlling pinging. Not trying to be argumentative, just want to learn.
jd74914
post Jul 16 2019, 07:53 PM
Its alive
QUOTE(bbrock @ Jul 16 2019, 08:04 PM) *
That's not quite the right way to think about. Modern engine controls can operate up to the bleeding edge of what the supplied fuel can provide to maximize performance, efficiency, etc. It really depends where you are in the map (ie: low load, low torque demand, high engine speed you may be shooting for max efficiency vs. high load/torque demand where you want power). They maximize performance based on the fuel characteristics (and air, engine temperature, etc. characteristics for that matter)
When I say operate at the bleeding edge this means that they manipulate spark timing up until the point detonation occurs and then back off. That means that you could put 87 into your STi instead of 93, but it will retard timing to prevent knocking. Just pulling timing might be a somewhat simplistic way of looking at it-the controls may be changing ignition timing, valve timing/lift to modify cylinder pressure (higher pressure lowers autoignition delay times), boost levels, etc. This could all be based on a measured knock limit, with changes happening after one knock event is detected. Or a misfire, etc.
Hopefully that answered your question in a somewhat roundabout way.
Edit: Just some food for thought: When modern engines have a single misfire, they have "missed" emissions requirements for literally the next tens of minutes to hours. Just one. That's how tight the controls are. I wish I could find the presentation that showed these figures-fascinating for people who like numbers.
IronHillRestorations   Gotta love the internet   Jul 15 2019, 09:29 PM
GaroldShaffer   Yep I seen that posting. How dare you call 914s a ...   Jul 15 2019, 10:36 PM
Larmo63   So, should I :idea: try half a tank of regular?   Jul 15 2019, 11:11 PM
steuspeed   Great info! My cheap ass always runs the lowes...   Jul 15 2019, 11:11 PM
Superhawk996   :WTF: There is no Santa Claus? 1) Facts don...   Jul 16 2019, 04:19 AM
bbrock   :WTF: There is no Santa Claus? 1) Facts don...   Jul 16 2019, 08:01 AM
jd74914   Well put. Hard to believe the octane thing is st...   Jul 16 2019, 08:43 AM
Superhawk996   I'm finishing my PhD; having spent the last...   Jul 16 2019, 10:51 AM
jd74914   Ha! You’re a better man than I. I took a ...   Jul 17 2019, 03:40 AM
914Sixer   I know just enough to be stupid.   Jul 16 2019, 05:52 AM
dr914@autoatlanta.com   excellent post, and in my opinion also dead on. I...   Jul 16 2019, 08:14 AM
Olympic 914   I use the 89 octane in the teener with somewhere a...   Jul 16 2019, 09:12 AM
UROpartsman   With an older car that only pings when it's ho...   Jul 16 2019, 09:43 AM
SirAndy   The whole point of higher octane is to make it har...   Jul 16 2019, 11:32 AM
Dave_Darling   Well, atmospheric pressure at somewhere near sea l...   Jul 16 2019, 11:53 AM
bbrock   And to add to the mess... the only ethanol-free ga...   Jul 16 2019, 03:02 PM
Chi-town   Combustion chamber design, spark plugs location, i...   Jul 16 2019, 05:57 PM
bbrock   Saying "you should always run the lowest oct...   Jul 16 2019, 07:04 PM
jd74914   Saying "you should always run the lowest oc...   Jul 16 2019, 07:53 PM
bbrock   Hopefully that answered your question in a somew...   Jul 16 2019, 09:19 PM
jd74914   Well not quite. If I'm understanding, that...   Jul 17 2019, 03:35 AM
tmc914   Well, I remember back in the the early 70's wh...   Jul 16 2019, 07:16 PM
914-300Hemi   Always learn something new here. I always use what...   Jul 16 2019, 08:47 PM
Chi-town   Is there an example of when running higher octane...   Jul 17 2019, 09:01 AM
jfort   There is a reason why they used to use lead as an ...   Jul 17 2019, 09:28 AM
- Lo-Fi Version Time is now: 11th July 2025 - 01:14 PM
