Sold-914-6GT brake calipers - FS |
mepstein |
Jul 15 2019, 03:35 PM
914-6 GT in waiting Group: Members Posts: 19,307 Joined: 19-September 09 From: Landenberg, PA/Wilmington, DE Member No.: 10,825 Region Association: MidAtlantic Region |
A real set of 914-6 calipers (not converted Ferrari calipers) were used to make this set of GT calipers. I also obtained the correct bolts and spacers and sent everything to PMB Performance. Eric and his team restored and replaced to make them like new or better. Offered at $1,895, email - mark@markepstein.net to purchase.
* color is a little off due to indoor lights. Attached thumbnail(s) |
sixnotfour |
Jul 17 2019, 12:54 PM
914 Wizard Group: Members Posts: 10,433 Joined: 12-September 04 From: Life Elevated..planet UT. Member No.: 2,744 Region Association: Rocky Mountains |
real GT rotors would be nice also....
quote from pmb website; QUOTE *Used with stock 911 rear rotors, these will need about 4.5mm worth of spacers (washers) under the caliper mounting ears or a spacer "under" the rotor. QUOTE Looking good Andy smilie_pokal.gif Before you paint or powder those, grind the handbrake adjustment tube flat on the wheel side as well. Depending on how you want to deal with the caliper/rotor offsent, you'll need as much room in there as possible for the caliper. You can put a 4.5mm spacer under the rotor hat but that will eat up a little clearance and, we can usually use all that we can get. That leaves spacing the calipers back with washers and they can hit the lip of the adjustment tube (you can see the lip sticking up past the weld on the factory tube). Just a heads up... |
Lo-Fi Version | Time is now: 2nd June 2024 - 02:19 AM |
