914/6 conversion, parting a 1970 911t |
injunmort |
Jul 19 2019, 09:48 AM
Senior Member Group: Members Posts: 1,024 Joined: 12-April 10 From: sugarloaf ny Member No.: 11,604 Region Association: North East States |
I have a solid 1974 914 tub and a very rusty 1970 911t. I don't want to repair the 911 and would like to do a /6 conversion on the 1974 tub. obviously, I need the engine out of the 911, but what else should I salvage for conversion? the 911 runs sort of, it has a sporto in it now, do I need to block off converter pump on engine ( will be using sideshift 901), do any of the oil lines/filter console etc transfer? thanks.
injunmort |
Jul 20 2019, 05:21 PM
thank you for info. the axles are not the same length, what do I use for drive shafts
/ already have mb's tins |
mepstein |
Jul 20 2019, 05:28 PM
914-6 GT in waiting Group: Members Posts: 19,313 Joined: 19-September 09 From: Landenberg, PA/Wilmington, DE Member No.: 10,825 Region Association: MidAtlantic Region |
thank you for info. the axles are not the same length, what do I use for drive shafts / already have mb's tins Per Eric Shea - "proper 914 axle length - 20.25". Then the 911 spline count - 28. Then a call to Sway-a-Way... yup, part number 2420. They run ~$320 pair. Eric thread is the best explanation out there. http://www.914world.com/bbs2/index.php?showtopic=91963 Since you have a sportomatic trans, you will need different trans stubs - 911 Tranny Flanges (901, 911 or early 915 transmissions) |
Lo-Fi Version | Time is now: 8th June 2024 - 06:27 AM |
