> Big Oil Problem., It started as a dribble...
Brando
post Nov 29 2004, 11:47 PM
BUY MY SPARE KIDNEY!!!
This evening when driving with a friend of mine down to riverside my oil light came on. Not just flickering, but on. Went away at about 2k RPMS. Then i started smelling burning oil. Not good.
After we get to the pool hall, I hop under and take a look. I saw about half a quart of oil on the ground under my car. The 3.5 quarts were maybe somewhere between Van Buren and Arlington Ave.
After about an hour of pool i go back to my car, put in the 'emergency' half-quart of oil. I also take this time to see that my entire engine compartment has oil sloshed all around. Underneath the car is pretty much oil-bathed everywhere. I started seeing brown and white streaks in the oil from the return line. This concerns me. I made it to a Kragen down the street, bought a 10-pack of 10W30 and put in 3 quarts. That lasted me a whopping 5 minutes before the burning oil smell and oil warning light returned. Pulled over, added 3 more quarts, and made it almost home. I had to turn the car off and coast for about a block to my house. While driving my friend noticed a 'sprinkler' sound, of spritzing maybe. All i heard was a 'SSSSSSSSSSSSSSS' and saw oil spraying out the back.
I'm really concerned here that something expensive (!!!) broke. All I know is that oil doesn't stay inside the case and that I hear a spraying sound when the engine is on. Any ideas? Suggestions? All input is apprecieated. (IMG:style_emoticons/default/pray.gif)
Dave_Darling
post Dec 1 2004, 04:12 PM
914 Idiot
QUOTE(jim912928 @ Nov 30 2004, 09:44 AM)
But when it's running I'm blowing oil front passenger side.
Jim, re-install the bolt where the pulley for the thermostat wire used to be. That is a hole that goes all the way into the sump, and oil will slosh (or sometimes spray) out of there while you're driving.
--DD
Brando   Big Oil Problem.   Nov 29 2004, 11:47 PM
scott thacher   oil gallery plug un seated and is spraying under p...   Nov 29 2004, 11:50 PM
MattR   Holy crap. We need to send some hazmat trucks to ...   Nov 29 2004, 11:51 PM
newdeal2   I have never had it happen personally but it does ...   Nov 30 2004, 12:10 AM
MattR   You might check your oil filter too. Aaron had a ...   Nov 30 2004, 12:16 AM
Jake Raby   Atleast if its that bad it'll be easy to find...   Nov 30 2004, 12:17 AM
Brando   I think you guys may have hit it on the head with ...   Nov 30 2004, 09:37 AM
jim912928   hmmm..mine is doing the same thing. Where are all...   Nov 30 2004, 11:44 AM
Jake Raby   There are 4 galleys in that area.... But it sounds...   Nov 30 2004, 11:47 AM
jim912928   Thanks Jake...my first chore this spring as the 91...   Nov 30 2004, 12:05 PM
ClayPerrine   Check the galley plugs at the top of the oil coole...   Nov 30 2004, 12:12 PM
Dave_Darling
- Lo-Fi Version Time is now: 2nd July 2025 - 11:36 PM
