| porschetub |
Aug 2 2019, 01:33 AM
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 5,176 Joined: 25-July 15 From: New Zealand Member No.: 18,995 Region Association: None |
Hi all,need the following small parts to complete current engine build and parts for the L-jet 1.7 motor.
Need; 1 x metal 3 bolt spacer behind crank fan 1 x thermostat mounting bracket ,found one online 2 x small spring steel tabs that hold the fan housing flap pivot rod. 1 x crankcase metal cover and bolt for oil strainer 1 x working or serviceable afm for 1.8 L-jet part Bosch number 0 280 200 012,must have free moving air gate. 1 x 3 pin altenator plug 1 x working thermostat, found one thanks Mike B 1 x dipstick Still looking thanks. Shipping to Portland Oregon 97203. TIA. |
| Tbone425 |
Aug 2 2019, 07:19 PM
Newbie ![]() Group: Members Posts: 48 Joined: 15-August 15 From: AZ/WA Member No.: 19,065 Region Association: Pacific Northwest |
Hi all,need the following small parts to complete current engine build and parts for the L-jet 1.7 motor. Need; 2 x thermostat mounting brackets 2 x dizzy clamps 1 x crankcase metal cover and bolt for oil strainer 1 x working afm for 1.8 L-jet part Bosch number 0 280 200 012. Shipping to Portland Oregon 97203. TIA. I have an ....020 afm no ide if it will work, but you can have it if you think it will. |
porschetub WTB a few small parts Aug 2 2019, 01:33 AM
Tbone425
Hi all,need the following small parts to complete... Aug 2 2019, 07:14 PM
porschetub
Hi all,need the following small parts to complet... Aug 14 2019, 05:11 PM
porschetub PM on the way,thanks so much :D . Aug 2 2019, 07:51 PM
porschetub
Hi all,need the following small parts to complete... Aug 13 2019, 02:10 PM
Dominic I should have the following parts, but I will need... Aug 13 2019, 06:49 PM
porschetub
I should have the following parts, but I will nee... Aug 14 2019, 10:59 PM
Mblizzard I have a dizzy clamp and thermostat. Aug 13 2019, 07:29 PM
porschetub Thanks Mike and Dominic ,keen as thanks Aug 14 2019, 12:42 AM
porschetub
Hi all,need the following small parts to complete... Aug 16 2019, 03:46 PM
porschetub
Hi all,need the following small parts to complete... Aug 28 2019, 08:31 PM
porschetub
Hi all,need the following small parts to complet... Aug 28 2019, 09:37 PM
porschetub
Hi all,need the following small parts to complete... Sep 14 2019, 01:58 PM
porschetub
Hi all,need the following small parts to complete... Sep 20 2019, 02:22 AM
porschetub
Hi all,need the following small parts to complete... Sep 23 2019, 01:35 PM![]() ![]() |
Lo-Fi Version | Time is now: 25th September 2026 - 12:30 PM |
