915 Transmission for 914 |
Jay Wellwood |
Aug 4 2019, 02:32 PM
Newbie Group: Members Posts: 14 Joined: 22-January 16 From: Atlanta Member No.: 19,588 Region Association: South East States |
Long time periodic lurker, first time poster.
Read a number of threads here and other forums. I *think* I understand this topic just enough to be dangerous to my checkbook. (IMG:style_emoticons/default/unsure.gif) That said, I think In understand that the 915 can be used in the 914 as a direct bolt-on to the chassis and will accommodate all of the 3.0, 3.2 and 3.6 air cooled engine variations. The ideal final drive ratio appears to be the 8.3:1 However, one still needs to do some work to complete this swap. A shift adapter kit, and a speedo adapter kit are needed to fully complete the mod. Kits are available from bugat 5 speed and Auto Atlanta (maybe other sources as well...). Also needs a special flywheel (patrick motorsports can hook you up with the right on) to provide the correct input needed for your engine management if using Motronic or other aftermarket standalone engine management system. How does this sound to the seasoned veterans here, missing something? What about axle shafts/CV joints to line the drive train tot he wheels? Thanks in advance for your constructive comments. (IMG:style_emoticons/default/beer3.gif) |
mepstein |
Aug 4 2019, 03:12 PM
914-6 GT in waiting Group: Members Posts: 19,315 Joined: 19-September 09 From: Landenberg, PA/Wilmington, DE Member No.: 10,825 Region Association: MidAtlantic Region |
The 915 doesn’t bolt onto the chassis unless you change the tail cone to a Wevo -$2,200 or Martin Bott (916 style) $3,200. You also need to flip the differential, fabricate a shift rod, use a 915 style shifter and the proper clutch. Also modify the trans for the electronic speedo if it’s a later trans. The trans will need to be notched for a 3.2 or 3.6 sensor.
Patrick sells the KEP (kennedy engineering products) conversion clutch and ring gear. You can also buy it direct from Kennedy for less. You also need clutch and throttle cables. You will need a conversion axle to connect the 915 trans stubs to the 911 hubs and stub axles. Sway away sells it. The best thread ever on 5 lug for big engines is the one Eric Shea wrote. http://www.914world.com/bbs2/index.php?showtopic=91963 (IMG:style_emoticons/default/welcome.png) |
Lo-Fi Version | Time is now: 9th June 2024 - 10:11 PM |
