Engine loses power, dies, but restarts in a minute, Diagnosis help please? |
SteveL |
Aug 4 2019, 04:58 PM
Senior Member Group: Members Posts: 658 Joined: 7-August 03 From: Andover, MN Member No.: 991 Region Association: None |
Happens when idling or driving. After 5-10 minutes, the engine loses all power, stepping on gas pedal does nothing. Engine dies. Restarts like nothing in wrong in 10 to 60 seconds and runs great for another 10 minutes.
74 1.8 L-Jet. Bosch 2 port updated fuel pump. Just getting it back on the road after being under a cover for 3 years. It had old gas, which I drained and replaced. New fuel filter after new fuel. The fuel pump was replaced 4 years ago, but only about 1000 miles on it. Old gas was, however pumped through it. I just replaced the fuel filter again, thinking it might be clogging up from the lines being rinsed with the new gas, but it made no difference. Ideas Please?? (IMG:style_emoticons/default/confused24.gif) |
dr914@autoatlanta.com |
Aug 5 2019, 07:45 AM
914 Guru Group: Members Posts: 7,896 Joined: 3-January 07 From: atlanta georgia Member No.: 7,418 Region Association: None |
easy and typical, losing power to the dual relay cutting power to the pump
Happens when idling or driving. After 5-10 minutes, the engine loses all power, stepping on gas pedal does nothing. Engine dies. Restarts like nothing in wrong in 10 to 60 seconds and runs great for another 10 minutes. 74 1.8 L-Jet. Bosch 2 port updated fuel pump. Just getting it back on the road after being under a cover for 3 years. It had old gas, which I drained and replaced. New fuel filter after new fuel. The fuel pump was replaced 4 years ago, but only about 1000 miles on it. Old gas was, however pumped through it. I just replaced the fuel filter again, thinking it might be clogging up from the lines being rinsed with the new gas, but it made no difference. Ideas Please?? (IMG:style_emoticons/default/confused24.gif) |
SteveL |
Aug 5 2019, 10:04 AM
[quote name='dr914@autoatlanta.com' date='Aug 5 2019, 05:45 AM' post='2735564']
easy and typical, losing power to the dual relay cutting power to the pump Doc - are you saying that the power lead to the relay is bad, or more likely that the relay itself is bad? I see that new relays are not exactly cheap (for a relay anyway). Thanks |
Lo-Fi Version | Time is now: 9th June 2024 - 09:14 AM |
