915 Transmission for 914 |
Jay Wellwood |
Aug 4 2019, 02:32 PM
Newbie Group: Members Posts: 14 Joined: 22-January 16 From: Atlanta Member No.: 19,588 Region Association: South East States |
Long time periodic lurker, first time poster.
Read a number of threads here and other forums. I *think* I understand this topic just enough to be dangerous to my checkbook. (IMG:style_emoticons/default/unsure.gif) That said, I think In understand that the 915 can be used in the 914 as a direct bolt-on to the chassis and will accommodate all of the 3.0, 3.2 and 3.6 air cooled engine variations. The ideal final drive ratio appears to be the 8.3:1 However, one still needs to do some work to complete this swap. A shift adapter kit, and a speedo adapter kit are needed to fully complete the mod. Kits are available from bugat 5 speed and Auto Atlanta (maybe other sources as well...). Also needs a special flywheel (patrick motorsports can hook you up with the right on) to provide the correct input needed for your engine management if using Motronic or other aftermarket standalone engine management system. How does this sound to the seasoned veterans here, missing something? What about axle shafts/CV joints to line the drive train tot he wheels? Thanks in advance for your constructive comments. (IMG:style_emoticons/default/beer3.gif) |
Jay Wellwood |
Aug 5 2019, 12:36 PM
Did you just go with the 19mm Master Cylinder to use the Boxster calipers?
Steve |
Aug 5 2019, 01:23 PM
914 Guru Group: Members Posts: 5,614 Joined: 14-June 03 From: Orange County, CA Member No.: 822 Region Association: Southern California |
Lo-Fi Version | Time is now: 9th June 2024 - 05:17 PM |
