Mark Henry |
that's what I do! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 20,065 Joined: 27-December 02 From: Port Hope, Ontario Member No.: 26 Region Association: Canada ![]() |
I have the room in my weber /6 conversion so I want to add a charcoal canister. I couldn't smell gas with a half tank, but I just filled up and I can smell just a whiff of gas, so I want to try a canister. I have the original plastic type out of my '74.
The can has a big smog hose each end and one end has the small line from the tank, which is the in and out sides? Also what would be the optimal inlet placement with K&N rain hats? |
JeffBowlsby |
914 Wiring Harnesses ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 8,549 Joined: 7-January 03 From: San Ramon CA Member No.: 104 Region Association: None ![]() ![]() |
Output of it goes to the air filter housing, before the filter. Don't know how it routes with carbs, but I imagine you would need a "T" to split it 50/50 to each carb.
Orientation of the charcoal canister is not gravity specific. Its just airflow through it. |
Lo-Fi Version | Time is now: 17th June 2024 - 02:30 AM |
