> Confirm my theory for fixing a non-starter?, rocket surgery
wobbletop
post Aug 6 2019, 10:49 AM
I thought I'd create a new thread instead of fouling the CanAm Mosport thread...
My 914 6 conversion died just as I got to Mosport. I could feel it stumble slightly on the last few km to the track. It's about an hour and 40 minutes of highway driving to get to the track. Temp gauge got up to about 212 and stayed.
Car stalled at the gate to the track and wouldn't start again.
Car would turn over but not catch and start. I could smell fuel from the exhaust and there was fuel in the clear fuel filter. Car would turn over, although it started getting slower and slower with the amount of cranking I was doing.
I figured I wasn't getting spark but it was tough to test in the parking lot, far from home.
Someone suggested a coil so Mark kindly brought one with him to the track, but swapping it out did nothing.
It also has a MSD6AL ignition and someone also said they go bad frequently.
Anyway, I towed it back home, pushed it into the garage, put the charger on the battery and left it for the next day.
Next day, with the charger still on it, the thing fired up right away. Turned it off, took the charger off, and it still fired up right away.
Checked the age of the battery (Optima red top) and it's older than the hills. Decided to swap the battery for a new one. The battery was old... terminal lugs were weak, and I could hear the battery bubbling internally.
So... the question is... is it just the battery?
At the side of the road, I figured if it could still crank the engine over, that the battery still should be able to provide spark, so I didn't consider just getting a new battery from CAA.
I'm thinking that maybe the MSD6AL requires more voltage to produce a spark, than the starter needs to turn over the engine, and this is why it would turn over but not start.
Can anyone with more experience with the MSD chime in and confirm this?
Should I get rid of the MSD? I like having it as it provides a soft rev limit for the engine.
Thanks for you attention,
Walter
Retroracer
post Aug 7 2019, 02:10 PM
So I have a similar set up to the OP; 914/6 conversion with a red top Optima and an MSD ignition module (Streetfire). The original 914/4 relay board and regulator are used, with the battery relocated to the front trunk. Have had no issues with the setup.
As to the described symptoms: I'd check the voltage regulator operation. Overcharging (from a malfunctioning regulator) can cook/damage a battery pretty badly. A depleted or weak battery would struggle cranking the engine over - but that seemed OK?
Not sure if sustained high voltage (for example: broken voltage regulator, freeway driving) would damage the MSD enough to cause a misfire or self protect somehow?
Curious mix of symptoms, but would suggest checking charging and voltage regulation with the new battery in place.
RE: "I checked the voltage when idling with the old battery and it was 13.25V. Not the best (I thought it should be 14V at least) but adequate." So that indicates alternator is doing something - increase revs and check it does not climb beyond 14V?
- Tony
porschetub
post Aug 7 2019, 08:03 PM
QUOTE(Retroracer @ Aug 8 2019, 08:10 AM) *
- Tony
AGM batteries are strange with charging,my 55amp 911 Bosch acts kind of weird with charging but is way better for my car as not started/driven as much as I would like (IMG:style_emoticons/default/sad.gif) .
I have a wet cell backup spare and it appears to charge as normal,buggered if I know.
Don't be put off buy your idle charge,it should however be above battery voltage if charging with a battery that needs it,14V is ok under rev's so your VR must be ok.
I run blue permatune box with matching $$$ transformer coil reason being its super reliable,went to go MSD and found a fairly high failure rate,heaps of used non functioning ones on ebay (IMG:style_emoticons/default/sad.gif) .
Good luck.
- Lo-Fi Version Time is now: 8th July 2025 - 02:56 PM
