> Electrical Issue After Engine Drop
HerdofCrickets
post Aug 12 2019, 12:20 PM
Dropped the engine last fall, had it rebuilt and we put it back in a month or so ago.
After having a little boy a few months ago, I'm finally getting a little time to get back to work on the 914.
Engine itself runs great, exhaust is really rich... so I guess the carb needs adjusted a little.
One issue though... no power to the dash (tach doesn't work and radio doesn't turn on).
Also when I turn the key, the engine tries to turn over but only fires when you let off the key.
Pretty sure I must have a wire hooked up wrong...
I'll start working backwards tonight but if anyone has any ideas... that'd be fantastic!
-Jon
post Aug 12 2019, 02:06 PM
QUOTE(HerdofCrickets @ Aug 12 2019, 11:20 AM) *
-Jon
I had that same experience with the ignition switch. Put a new battery in and that did the trick. What kind of voltage are you seeing at the battery. Is the blk wire w/ purple stripe connected at the coil?
- Lo-Fi Version Time is now: 14th September 2026 - 04:57 PM
