At what displacement are external coolers needed?, Building an alternative engine for my six |
Speedo |
Aug 12 2019, 02:24 PM
Senior Member Group: Members Posts: 529 Joined: 7-November 06 From: Boulder Member No.: 7,170 Region Association: Rocky Mountains |
I have read that the general consensus is above 180 hp an external cooler is needed.
I am at a crossroads with the 2.2 T I am building. I have 2.2 S pistons and cylinders and and cams. If I stroke it I get a higher cr 2.4 S. If I don't stroke it I get a decent 2.2 S which would still be a nice choice. I have everything I need for the 2.2, but if I stroke it I will need to source a 70.4 crank. Curious what the board thinks about the "red line in the sand" for needing cooling. It goes without saying that I am not interested in cutting on the six for a cooler up front. Having said that...I spoke with a friend over the weekend with a 76 911 with a 3.2 transplant that doesn't run a cooler. He says his temps never go over 210...which I question as I have a stock 74 2.7 with a modified pulley setup that runs 200 but will show 230 when pushed. I think I need to measure his temps with a pyrometer to double check his temp gauge. (IMG:style_emoticons/default/bs.gif) Tell me what you guys think! (IMG:style_emoticons/default/idea.gif) |
mb911 |
Aug 12 2019, 03:04 PM
914 Guru Group: Members Posts: 6,875 Joined: 2-January 09 From: Burlington wi Member No.: 9,892 Region Association: Upper MidWest |
I would suggest a front cooler.. I am going to run a front cooler with no engine cooler.. Should be perfect for my 2.4 s built engine.
Lo-Fi Version | Time is now: 5th June 2024 - 02:52 AM |
