| Sprout |
Aug 12 2019, 01:28 PM
Member ![]() ![]() Group: Members Posts: 125 Joined: 5-October 18 From: Kansas City Member No.: 22,544 Region Association: Upper MidWest |
A little guidance, please...I've replaced the ignition switch in my '73 1.7 FI twice now with Meistersatz parts, and the car is dead again. Has only been started a couple dozen times between these two switches. When I turn the key, I have lights on the dash and can hear the fuel pump engage, but the engine does not crank. Battery is at 12.5 and just installed a reman Bosch starter/solenoid. It can be push-started.
From what I've read the switches seem to fail fairly often, but only starting the car a dozen times per switch seems pretty ridiculous. Are the genuine Porsche switches that much better? Do you think I could have something shorting out the switch? The 914 key is the only thing on my keyring, so I know it's not an extra weight problem. When it's running, it runs great! |
| Mark Henry |
Aug 12 2019, 03:25 PM
that's what I do! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 20,065 Joined: 27-December 02 From: Port Hope, Ontario Member No.: 26 Region Association: Canada |
My ford solenoid mod takes the load off of the ignition switch. I don't know if it helps with the aftermarket switches.
Link in my signature below. |
Sprout Second ignition switch failed? Aug 12 2019, 01:28 PM
Superhawk996 China is a funny place.
I've seen amazing hig... Aug 12 2019, 01:36 PM
76-914
A little guidance, please...I've replaced the... Aug 12 2019, 01:51 PM
nditiz1 I have 2 new in box ones for sale. Can't tell... Aug 12 2019, 02:37 PM
framos914 Had same problem, went through a few switches. Pro... Aug 12 2019, 02:45 PM
sixnotfour is the yellow wire under pass seat , bypass mode,,... Aug 12 2019, 02:46 PM
orthobiz I did a thread on this in the Parts Vault:
http:/... Aug 12 2019, 04:35 PM
RoadGlue
A little guidance, please...I've replaced the... Aug 12 2019, 07:39 PM
Amphicar770 Does having a gear reduction starter reduce the lo... Aug 12 2019, 08:01 PM
Mark Henry
Does having a gear reduction starter reduce the l... Aug 13 2019, 06:57 PM
Chris914n6 How worn is the cam that turns the switch?
Mine w... Aug 12 2019, 08:48 PM
914Toy Unless you are maintaining originality, consider i... Aug 13 2019, 07:17 PM
Sprout Thank you, everyone, for the replies and ideas... Aug 14 2019, 05:11 PM
sixnotfour
is that confirmed Aug 14 2019, 06:25 PM
Mblizzard It is just a fact of time and entropy that the eff... Aug 14 2019, 07:38 PM
Sprout Well, easy come, easy go. I picked up my OEM ignit... Aug 19 2019, 03:36 PM
Superhawk996
Well, easy come, easy go. I picked up my OEM igni... Aug 19 2019, 04:09 PM
Highland Since I'm a cheap 914 SOB I just wanted to mak... Aug 20 2019, 11:44 AM![]() ![]() |
Lo-Fi Version | Time is now: 24th November 2026 - 04:48 AM |
