> Second ignition switch failed?
Sprout
post Aug 12 2019, 01:28 PM
A little guidance, please...I've replaced the ignition switch in my '73 1.7 FI twice now with Meistersatz parts, and the car is dead again. Has only been started a couple dozen times between these two switches. When I turn the key, I have lights on the dash and can hear the fuel pump engage, but the engine does not crank. Battery is at 12.5 and just installed a reman Bosch starter/solenoid. It can be push-started.
From what I've read the switches seem to fail fairly often, but only starting the car a dozen times per switch seems pretty ridiculous. Are the genuine Porsche switches that much better?
Do you think I could have something shorting out the switch? The 914 key is the only thing on my keyring, so I know it's not an extra weight problem.
When it's running, it runs great!
RoadGlue
post Aug 12 2019, 07:39 PM
Sonoma County Gear Head
QUOTE(Sprout @ Aug 12 2019, 12:28 PM) *
I had the exact same problem with my '74. Sometimes it would crank and rather frequently you'd hear the pump run but the starter wouldn't engage. I pulled the ignition switch, and wouldn't ya know it, the back of the housing was cracked.
Purchased a new switch, installed it, seemed to work fine and then shortly after had the same issue. Pulled it out, and hey, it's slightly cracked again. WTF.
Installed a second new switch and it had the same behavior. This time I decided to hunt around and found that if I wiggled the relays under the passenger seat while holding the switch to "START" I could get it to crank.
Do exactly what "sixnotfour" posted. Bypass all the seatbelt interconnect BS and I bet you'll be on your way. If not, it could be a bad starter solenoid. I'd say ignore any cracks in the ign switch housing for now until you confirm nothing else is causing the issue.
Sprout   Second ignition switch failed?   Aug 12 2019, 01:28 PM
Superhawk996   China is a funny place. I've seen amazing hig...   Aug 12 2019, 01:36 PM
76-914   A little guidance, please...I've replaced the...   Aug 12 2019, 01:51 PM
nditiz1   I have 2 new in box ones for sale. Can't tell...   Aug 12 2019, 02:37 PM
framos914   Had same problem, went through a few switches. Pro...   Aug 12 2019, 02:45 PM
sixnotfour   is the yellow wire under pass seat , bypass mode,,...   Aug 12 2019, 02:46 PM
Mark Henry   My ford solenoid mod takes the load off of the ign...   Aug 12 2019, 03:25 PM
orthobiz   I did a thread on this in the Parts Vault: http:/...   Aug 12 2019, 04:35 PM
RoadGlue   A little guidance, please...I've replaced the...   Aug 12 2019, 07:39 PM
Amphicar770   Does having a gear reduction starter reduce the lo...   Aug 12 2019, 08:01 PM
Mark Henry   Does having a gear reduction starter reduce the l...   Aug 13 2019, 06:57 PM
Chris914n6   How worn is the cam that turns the switch? Mine w...   Aug 12 2019, 08:48 PM
914Toy   Unless you are maintaining originality, consider i...   Aug 13 2019, 07:17 PM
Sprout   Thank you, everyone, for the replies and ideas...   Aug 14 2019, 05:11 PM
sixnotfour   is that confirmed   Aug 14 2019, 06:25 PM
Mblizzard   It is just a fact of time and entropy that the eff...   Aug 14 2019, 07:38 PM
Sprout   Well, easy come, easy go. I picked up my OEM ignit...   Aug 19 2019, 03:36 PM
Superhawk996   Well, easy come, easy go. I picked up my OEM igni...   Aug 19 2019, 04:09 PM
Highland   Since I'm a cheap 914 SOB I just wanted to mak...   Aug 20 2019, 11:44 AM
- Lo-Fi Version Time is now: 24th November 2026 - 04:48 AM
