| HerdofCrickets |
Aug 12 2019, 12:20 PM
Member ![]() ![]() Group: Members Posts: 68 Joined: 23-September 16 From: Overland Park, KS Member No.: 20,423 Region Association: None |
Dropped the engine last fall, had it rebuilt and we put it back in a month or so ago.
After having a little boy a few months ago, I'm finally getting a little time to get back to work on the 914. Engine itself runs great, exhaust is really rich... so I guess the carb needs adjusted a little. One issue though... no power to the dash (tach doesn't work and radio doesn't turn on). Also when I turn the key, the engine tries to turn over but only fires when you let off the key. Pretty sure I must have a wire hooked up wrong... I'll start working backwards tonight but if anyone has any ideas... that'd be fantastic! -Jon |
| Chi-town |
Aug 13 2019, 12:31 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 851 Joined: 31-August 18 From: Disneyland Member No.: 22,446 Region Association: Southern California |
Yes as the alternator is grounded to the engine, not the chassis so you need the strap
HerdofCrickets Electrical Issue After Engine Drop Aug 12 2019, 12:20 PM
76-914
Dropped the engine last fall, had it rebuilt and ... Aug 12 2019, 02:06 PM
HerdofCrickets
I had that same experience with the ignition swi... Aug 12 2019, 03:22 PM
ClayPerrine Black with purple wire goes to the negative termin... Aug 12 2019, 05:24 PM
Mike Bellis Bad tranny ground. Aug 12 2019, 10:02 PM
HerdofCrickets
Bad tranny ground.
Thank you! I would not ... Aug 13 2019, 07:09 AM
HerdofCrickets
Bad tranny ground.
Would a bad/poor tranny grou... Aug 13 2019, 11:12 AM
HerdofCrickets
Yes as the alternator is grounded to the engine, ... Aug 13 2019, 01:39 PM![]() ![]() |
Lo-Fi Version | Time is now: 14th September 2026 - 04:58 PM |
