| 9fourteen14 |
Aug 13 2019, 12:52 PM
PORSCHE LUVA ![]() ![]() Group: Members Posts: 135 Joined: 5-July 15 From: boston Member No.: 18,920 Region Association: North East States |
so i have a 74 2.0 914
problem: my emergency brake light continues to flash even when i raise the emergency brake. I got pelican parts diagnosis and possible cure but i don't think i have the same switch because i do not see a little plastic button i can switch towards the master cyclinder. see pictures below. BTW: my switch is rusted a lot. there are 2 varieties pelican points out:1: low pressure when pedal is pushed to floor and reset hen lift off floor (I am NOT seeing that) 2: pressure failure and then remains locked until manually reset. WHERE IS THE BUTTON TO RESET IT? I DO NOT SEE IT? check out the 2 pictures.... any other ideas? thanx Niece Attached thumbnail(s) |
| lierofox |
Aug 13 2019, 01:01 PM
Member ![]() ![]() Group: Members Posts: 256 Joined: 23-June 15 From: Paso Robles, CA Member No.: 18,880 Region Association: Southern California
There seems to be a couple different switches I've seen used in the MC.
The one with the reset button is visible in this thread: http://www.914world.com/bbs2/index.php?sho...p;#entry1750709 |
9fourteen14 Emergency brake warning light Aug 13 2019, 12:52 PM
914_teener That circuit is tricky and works through a series ... Aug 13 2019, 01:00 PM
914Sixer NO reset on that one. There was a two pole (70-73... Aug 13 2019, 01:04 PM
Spoke If you remove the wire on the MC switch, does the ... Aug 13 2019, 07:23 PM![]() ![]() |
Lo-Fi Version | Time is now: 17th November 2026 - 12:33 PM |
