> Newbie needs purchase advice, Purchase advise
Indyheel
post Aug 17 2019, 08:27 PM
Hi Everyone,
I'm new to the 914 world and am looking at a '73. The car is from Colorado and was dry stored for 23 years. Car is relatively rust free with the exception of a small area by the drivers door sill. I've attached pics of the battery area. Would do you think?
Superhawk996
post Aug 18 2019, 11:56 AM
Run Forrest, Run . . . .
poorsche914
post Aug 18 2019, 12:03 PM
9fourteen
Perhaps more info and images will aid in guiding OP ... from the CL ad:
Great, rust free solid car. Recently tuned--New plugs, condenser, points. Fuel pump upgrade and new stainless lines to replace the old vinyl lines that could catch these on fire.
Purchased last year out of Colorado where is sat in dry storage for about 20 years. Last driven and tagged in 1996, but it runs great now with no smoke and a smooth idle.
Great project car to clean up the body or even keep in its original survivor patina. I have lots of parts from the previous owner including brakes, A/C, ignition parts, trim parts, new seat covers, fuel tank cleaner (not needed). The car is complete and just needs a little effort to get it into great shape.
Superhawk996
post Aug 18 2019, 12:35 PM
QUOTE(poorsche914 @ Aug 18 2019, 02:03 PM) *
Quick things I see in the photos:
1) interior is roached. Budget $2K at least to make this decent driver quality. If you want it pristine, you'll be in for more like $5K.
2) Door jamb rust on driver side is a bit unusual. If you can see that there is easily in that spot, there is 20X more hidden around the vehicle that isn't easily seen. Insist that owner pull the passenger side outer rocker panel before buying.
3) Trunk hinge on passenger side above battery has been broken and has been poorly welded as the quick repair.
4) the rusted battery tray surely dumped acid laden water and acid onto the engine bay longitudinal. Hell Hole needs to be checked way more closely. Haven't seen a picuture of it yet down in the low corner at the firewall where the rust happens.
5) 1st gear Syncro is no the end of the world but likely that isn't all the trans needs.
6) fuel injection lines have standard worm clamp on them. This is a fire waiting to happen. These lines need proper clamps that don't cut into and extrude the rubber though them.
7) luggage rack add on virtually guarantees that you now have corrosion starting on the trunk. At a bare minimum, you now have holes.
8) Car has had A/C installed. There are multiple holes cut into this vehicle that are sources of corrosion and leakage. I know, my car had A/C installed and I'm working to fix the damage. All A/C installed of the era involved pure butchery!
9) where did all the center console gauges go?
And that is what I see in a 30 second rundown. I'm sure there is way more.
Previous advise stands. Consider this a learning exercise in how to inspect and buy a 914. You've come to the right place for expert advice. The guys on the forum will help protect you from yourself. Don't fall in love with this one.
Unless you can weld and do all work yourself this is a money pit.
Love that color. My first car started the same color. And like a dope I painted it red in the 80's -- what was I thinking. Changing it to red cost me thousands in speeding tickets!
Indyheel   Newbie needs purchase advice   Aug 17 2019, 08:27 PM
Porschef   :wttc: Welcome. Post lots of pics and introduc...   Aug 18 2019, 07:10 AM
Cairo94507   :wttc: What he said. Looks like you might have a ...   Aug 18 2019, 07:27 AM
thelogo   Hi Everyone, I'm new to the 914 world and am ...   Aug 18 2019, 07:38 AM
Rand   please dont buy the first one you see . i looked ...   Aug 18 2019, 06:28 PM
DickSteinkamp   Looks like someone torched out the floor of the ba...   Aug 18 2019, 10:04 AM
rjames   The battery tray can easily be replaced. What does...   Aug 18 2019, 10:06 AM
Indyheel   Thanks for the feedback so far. Here is a pic of ...   Aug 18 2019, 10:12 AM
DickSteinkamp   Thanks for the feedback so far. Here is a pic of...   Aug 18 2019, 10:19 AM
bbrock   A couple thoughts from the jamb/sill pic. That is...   Aug 18 2019, 10:20 AM
Indyheel   Here is the underside of the drivers door sill. T...   Aug 18 2019, 10:23 AM
rjames   Here is the underside of the drivers door sill. ...   Aug 18 2019, 10:35 AM
Spoke   Here is the underside of the drivers door sill. ...   Aug 18 2019, 11:36 AM
JawjaPorsche   There is a lot of rust you can’t see. I would c...   Aug 18 2019, 10:43 AM
Larmo63   :agree: Walk away unless you have lots of patien...   Aug 18 2019, 11:37 AM
burton73   :agree: Walk away unless you have lots of patie...   Aug 18 2019, 04:14 PM
Superhawk996   :agree: Run Forrest, Run . . . .   Aug 18 2019, 11:56 AM
poorsche914   Perhaps more info and images will aid in guiding O...   Aug 18 2019, 12:03 PM
Superhawk996   Perhaps more info and images will aid in guiding ...   Aug 18 2019, 12:35 PM
rjames   Owner has had it less than a year and is now tryin...   Aug 18 2019, 12:06 PM
DickSteinkamp   I've seen worse. After a careful inspection...   Aug 18 2019, 01:30 PM
Superhawk996   I've seen worse. :rotfl: I own worse....   Aug 18 2019, 01:34 PM
Indyheel   Thanks for the feedback everyone. The color, appe...   Aug 18 2019, 02:08 PM
Superhawk996   Thanks for the feedback everyone. The color, app...   Aug 18 2019, 02:16 PM
DickSteinkamp   Thanks for the feedback everyone. The color, app...   Aug 18 2019, 02:17 PM
Superhawk996   Thanks for the feedback everyone. The color, ap...   Aug 18 2019, 02:27 PM
bbrock   I agree with pretty much everything already said. ...   Aug 18 2019, 02:44 PM
Tdskip   But the seller says it is “rust free”. Dear Lo...   Aug 18 2019, 04:37 PM
thelogo   Buying a car off the 914 classifed section here wo...   Aug 18 2019, 05:01 PM
Indyheel   A big "Thank you!" to all of you for...   Aug 18 2019, 05:31 PM
Superhawk996   :trophy: :beer2: You will find a better one.   Aug 18 2019, 05:40 PM
DickSteinkamp   I think you can still get a good, driver quality 9...   Aug 18 2019, 06:21 PM
PanelBilly   And don’t be afraid to ask for someone to do an ...   Aug 19 2019, 09:25 AM
rjames   Keep in mind that these cars are old and require...   Aug 19 2019, 10:54 AM
dr914@autoatlanta.com   an easy repair. The new tray can be spot welded to...   Aug 19 2019, 11:25 AM
Rand   I'm really surprised to hear this from an exp...   Aug 20 2019, 07:21 PM
mepstein   When the sill looks like this, it’s usually the ...   Aug 20 2019, 08:28 PM
Rand   Shh, George could sell you a new sill plate. It wi...   Aug 20 2019, 08:40 PM
rhodyguy   $20k in fixes, new parts and upgrades will NO...   Aug 21 2019, 09:28 AM
sixnotfour   youall this is the kill shot....... battery tray i...   Aug 21 2019, 12:37 PM
Rand   Dr said it's an easy fix and he has the part a...   Aug 21 2019, 01:19 PM
- Lo-Fi Version Time is now: 2nd April 2026 - 08:39 PM
