Sealing nuts, Chasing oil leaks all the way |
worn |
Aug 17 2019, 08:08 PM
can't remember Group: Members Posts: 3,163 Joined: 3-June 11 From: Madison, WI Member No.: 13,152 Region Association: Upper MidWest |
So, the 911 motor died in montana, the six conversion was considering jettisoning the tranny, and on the lift is the four cylinder 914. For a brief time i figured the fracking had paid off, but now I have to admit major problems with oil leaks.
Most of the trouble is probably from the oil pump gaskets, Melling. Along with oil filter console leaks. I also want to replace the case bolt sealing nuts with new ones. I cannot find them though. All that i can find are 12 mm nuts for type 1-3 engines. Have they really stopped making the sealing nuts? They look like nyloc nuts with rubber in place of nylon. Thanks folks. Warren |
914Sixer |
Aug 18 2019, 01:33 PM
914 Guru Group: Members Posts: 8,903 Joined: 17-January 05 From: San Angelo Texas Member No.: 3,457 Region Association: Southwest Region |
I have bags of the 12m nylock nuts. Did you check with Porsche or VW dealer. Picture is of 12 x 1.75 mm
Attached image(s) |
Lo-Fi Version | Time is now: 8th June 2024 - 03:27 AM |
