Sealing nuts, Chasing oil leaks all the way |
worn |
Aug 17 2019, 08:08 PM
can't remember Group: Members Posts: 3,156 Joined: 3-June 11 From: Madison, WI Member No.: 13,152 Region Association: Upper MidWest |
So, the 911 motor died in montana, the six conversion was considering jettisoning the tranny, and on the lift is the four cylinder 914. For a brief time i figured the fracking had paid off, but now I have to admit major problems with oil leaks.
Most of the trouble is probably from the oil pump gaskets, Melling. Along with oil filter console leaks. I also want to replace the case bolt sealing nuts with new ones. I cannot find them though. All that i can find are 12 mm nuts for type 1-3 engines. Have they really stopped making the sealing nuts? They look like nyloc nuts with rubber in place of nylon. Thanks folks. Warren |
Superhawk996 |
Aug 18 2019, 02:24 PM
914 Guru Group: Members Posts: 5,875 Joined: 25-August 18 From: Woods of N. Idaho Member No.: 22,428 Region Association: Galt's Gulch |
Note, the leakage isn't likely to come past the Nylock insert.
Where they do leak is from between the washer and the case, between the washer topside and the nut. I put down a little Permatex between the case and the washer and a dab of YamaBond between the washer topside and the nut on final assembly. This area isn't under pressure if the PCV system is working properly. More of a weep risk than an outright leak. |
worn |
Aug 18 2019, 05:19 PM
Note, the leakage isn't likely to come past the Nylock insert. Where they do leak is from between the washer and the case, between the washer topside and the nut. I put down a little Permatex between the case and the washer and a dab of YamaBond between the washer topside and the nut on final assembly. This area isn't under pressure if the PCV system is working properly. More of a weep risk than an outright leak. I thought that the bolts were made to run through oil galleries in the case, and therefore subject to around 3 bar of pressure. I agree that this isnt a big worry area, but am surprised i cannot find the nuts. Perhaps the nyloc nuts will do the same thing as the rubber sealing nuts. Thanks |
Lo-Fi Version | Time is now: 1st June 2024 - 11:20 AM |
