Sealing nuts, Chasing oil leaks all the way |
worn |
Aug 17 2019, 08:08 PM
can't remember Group: Members Posts: 3,162 Joined: 3-June 11 From: Madison, WI Member No.: 13,152 Region Association: Upper MidWest |
So, the 911 motor died in montana, the six conversion was considering jettisoning the tranny, and on the lift is the four cylinder 914. For a brief time i figured the fracking had paid off, but now I have to admit major problems with oil leaks.
Most of the trouble is probably from the oil pump gaskets, Melling. Along with oil filter console leaks. I also want to replace the case bolt sealing nuts with new ones. I cannot find them though. All that i can find are 12 mm nuts for type 1-3 engines. Have they really stopped making the sealing nuts? They look like nyloc nuts with rubber in place of nylon. Thanks folks. Warren |
Superhawk996 |
Aug 18 2019, 05:29 PM
914 Guru Group: Members Posts: 5,891 Joined: 25-August 18 From: Woods of N. Idaho Member No.: 22,428 Region Association: Galt's Gulch |
As far as I can tell from looking at my split cases, the galley comes in above or below the main bolt bores and doesn't intersect.
I didn't run a borescope though them but I can't see an intersection looking into them. That would be silly to have 30-60 psi of oil pressure sitting behind those washers. Take a look at yours, but, there is no way for the oil to get to or past the nylock portion without first leaking around the washer and the bolt shaft. I don't remember ever seeing rubber in any of these nuts, Only brittle old nylock material (red). Somebody tell me if I'm off my rocker. There are anti-vibration clips that go on these long bolts at the middle of the case split but again, not for sealing. They prevent the unsupported bolt span from resonating and loosening. |
Lo-Fi Version | Time is now: 7th June 2024 - 12:49 PM |
