Rear end alignment for Dummies?, Negative camber adjustment - is there a good How to do it write up? |
DRPHIL914 |
Aug 20 2019, 12:04 PM
Dr. Phil Group: Members Posts: 5,768 Joined: 9-December 09 From: Bluffton, SC Member No.: 11,106 Region Association: South East States |
one simple question also,
if you add 2mm shim does anyone know about how much change this creates?, like 2mm increased shim equates to an additional (x) degrees of negative camber? Phil |
SirAndy |
Aug 20 2019, 01:05 PM
Resident German Group: Admin Posts: 41,675 Joined: 21-January 03 From: Oakland, Kalifornia Member No.: 179 Region Association: Northern California |
one simple question also, if you add 2mm shim does anyone know about how much change this creates?, like 2mm increased shim equates to an additional (x) degrees of negative camber? Adding shims removes negative camber! To get the max. negative camber, remove all shims. Unfortunately the chassis vary enough that you never get exactly the same camber on different cars. Plus, any damage to the chassis near the pickup points and/or bend trailing arms will affect camber as well. I'm getting just shy of -2 degrees without any shims. (IMG:style_emoticons/default/popcorn[1].gif) |
Lo-Fi Version | Time is now: 7th June 2024 - 10:14 AM |
