Rear end alignment for Dummies?, Negative camber adjustment - is there a good How to do it write up? |
DRPHIL914 |
Aug 20 2019, 12:04 PM
Dr. Phil Group: Members Posts: 5,768 Joined: 9-December 09 From: Bluffton, SC Member No.: 11,106 Region Association: South East States |
one simple question also,
if you add 2mm shim does anyone know about how much change this creates?, like 2mm increased shim equates to an additional (x) degrees of negative camber? Phil |
Mblizzard |
Aug 20 2019, 01:28 PM
Advanced Member Group: Members Posts: 3,033 Joined: 28-January 13 From: Knoxville Tn Member No.: 15,438 Region Association: South East States |
Retroracer |
Aug 20 2019, 02:52 PM
Senior Member Group: Members Posts: 616 Joined: 7-July 13 From: Bend OR Member No.: 16,100 Region Association: Pacific Northwest |
The above is a great read!! Note also a key point: that lowering the ride height will increase negative camber due to the trailing arm geometry. generally speaking, lowering the car will add more negative camber, so you end up adding shims to push it back towards zero. Setting ride height before any camber adjustment is therefore key, obvs. Tangerine Racing sells a useful assortment of varying shim thicknesses, FYI. - Tony |
Lo-Fi Version | Time is now: 7th June 2024 - 09:02 AM |
