Ultrasonic Cleaners - heated, Looking for suggestions and or observations |
ssuperflyoldguy |
Aug 17 2019, 03:53 PM
Member Group: Members Posts: 173 Joined: 15-November 15 From: NorCal - East Bay Baby! Member No.: 19,364 Region Association: None |
Not something I would use every day but when I need it...
On my Mini forum someone has one they got one eBay for $100 but can’t tell me which one, it would be nice to have larger than a smaller one - plan is for carbs, hubs etc. wanted to throw it out there. Also, what fluids are being used...? Thx |
markhoward |
Aug 19 2019, 09:30 AM
Member Group: Members Posts: 378 Joined: 5-March 17 From: Lafayette, CA Member No.: 20,897 Region Association: Northern California |
Dr Evil |
Aug 20 2019, 09:28 AM
Send me your transmission! Group: Members Posts: 23,002 Joined: 21-November 03 From: Loveland, OH 45140 Member No.: 1,372 Region Association: MidAtlantic Region |
Bought this Solid Tech off amazon which was recommended on a pelican thread. been using mix of water/dawn/simple green. dawn is they key. been using it regularly for 4 years now and still going strong. heated solution does a great job even if not running the ultrasonic part. I just bought this exact unit from same supplier. Large enough for all trans parts except shaft and case. It was an experiment as I also do carbs and motorcycle parts. Works ok. loosens everything. I am using simple green, water. Need to add Dawn and see how that goes. No probs with my mag and aluminum as of yet. The real deal is the vapor blast cabinet I am building (IMG:style_emoticons/default/happy11.gif) |
mepstein |
Aug 21 2019, 10:01 AM
914-6 GT in waiting Group: Members Posts: 19,316 Joined: 19-September 09 From: Landenberg, PA/Wilmington, DE Member No.: 10,825 Region Association: MidAtlantic Region |
Bought this Solid Tech off amazon which was recommended on a pelican thread. been using mix of water/dawn/simple green. dawn is they key. been using it regularly for 4 years now and still going strong. heated solution does a great job even if not running the ultrasonic part. I just bought this exact unit from same supplier. Large enough for all trans parts except shaft and case. It was an experiment as I also do carbs and motorcycle parts. Works ok. loosens everything. I am using simple green, water. Need to add Dawn and see how that goes. No probs with my mag and aluminum as of yet. The real deal is the vapor blast cabinet I am building (IMG:style_emoticons/default/happy11.gif) I'm a big fan of vapor blasting ever since I sent out my motorcycle parts to get done. Our cabinet is almost too big for our shop use. It took a separate transformer to run power and a shop size snap-on compressor to run enough air. It can fit 3 transmissions on it's turntable. But it does get the job done and makes the parts pretty. |
Lo-Fi Version | Time is now: 10th June 2024 - 09:18 AM |
