Which lifters? |
Which lifters? |
MikeM |
Aug 22 2019, 10:58 AM
Senior Member Group: Members Posts: 564 Joined: 16-May 10 From: Calgary, Canada Member No.: 11,733 Region Association: Canada |
Hi all...the cam from my 2 liter is out for re-grind. Assuming it can be done successfully, which new lifters are you guys recommending?
Thanks |
Highland |
Aug 23 2019, 10:34 AM
Senior Member Group: Members Posts: 513 Joined: 8-August 11 From: San Diego, CA Member No.: 13,418 Region Association: Southern California |
I wasn't sure which lifters to use either for a regrind cam, so I just re-used the stock lifters.
I sent 2 sets of stock lifters to Elgin for regrind. He said one set was past wear limits, the other set he reground for use with the 330-1 cam. Was that a bad thing to do? (IMG:style_emoticons/default/confused24.gif) |
jcd914 |
Aug 23 2019, 12:50 PM
Advanced Member Group: Members Posts: 2,081 Joined: 7-February 08 From: Sacramento, CA Member No.: 8,684 Region Association: Northern California |
I wasn't sure which lifters to use either for a regrind cam, so I just re-used the stock lifters. I sent 2 sets of stock lifters to Elgin for regrind. He said one set was past wear limits, the other set he reground for use with the 330-1 cam. Was that a bad thing to do? (IMG:style_emoticons/default/confused24.gif) No not a bad thing. Elgin would not have sent you anything back that was not done right. Every Elgin reground cam I have ever used, got stock or aftermarket stock equivalent lifters installed with it. The stock lifters have a hardened layer that can be ground flat again but if the lifter is worn too far there is not enough of the hardened layer left to grind. That is why Elgin said one set was past the wear limit. The stock cam is hardened all the way through the blank and provided it is ground with proper cooling/lubrication it does not require retreating or hardening to get the same surface as it started with. Jim |
Lo-Fi Version | Time is now: 1st June 2024 - 01:11 PM |
