> Double Relay After Carb Conversion, Is there any use for the Double Relay After Carb Conversion?
downrange
post Aug 23 2019, 10:51 AM
I am converting L Jetronic fuel Injection to single carb with electric choke. Is there any use for the double relay?
JeffBowlsby
post Aug 23 2019, 09:10 PM
Several skilled and experienced 914 owners have spoken here, not in an effort to be critical but recognize that in this community, many are willing to give you the benefit of their wisdom from lessons learned (mistakes made) by those who have done what you are intending to do now. Please do not take their recommendations lightly. What you have not mentioned is the purpose and expectations you hope to achieve from the single carb, but you don't need ours or anyone's approval.
That said, the L-Jet ignition harness will need significant modification to use with carbs, basically a full rebuild and reconfiguration. A D-Jet ignition harness is the plug N play solution for carbs.
downrange   Double Relay After Carb Conversion   Aug 23 2019, 10:51 AM
SirAndy   Noooooooooo That's for both, the "conver...   Aug 23 2019, 11:18 AM
jcd914   L-jet is a good FI system in general and is usuall...   Aug 23 2019, 12:38 PM
Tdskip   Don’t do it without a REALLY good reason. Why a...   Aug 23 2019, 12:51 PM
rhodyguy   If you go the carb route, plan on a new low pressu...   Aug 23 2019, 02:23 PM
porschetub   Real backwards step in terms of efficiency and rel...   Aug 23 2019, 03:00 PM
dr914@autoatlanta.com   don't do it! You will be very unhappy. Th...   Aug 23 2019, 03:32 PM
downrange   The carb conversion is underway. A simple answer ...   Aug 23 2019, 08:30 PM
GregAmy   lol...poor guy... A simple answer to a simple que...   Aug 24 2019, 07:00 AM
downrange   lol...poor guy... A simple answer to a simple qu...   Aug 25 2019, 08:09 PM
JeffBowlsby   Several skilled and experienced 914 owners have sp...   Aug 23 2019, 09:10 PM
porschetub   Several skilled and experienced 914 owners have s...   Aug 24 2019, 01:17 AM
dr914@autoatlanta.com   Sime answer is "no. You're going to be co...   Aug 24 2019, 09:01 AM
Rand   Wow. Just buy a cheap Civic until you can do a 914...   Aug 24 2019, 09:07 AM
dr914@autoatlanta.com   Amen brother Wow. Just buy a cheap Civic until ...   Aug 24 2019, 10:28 AM
downrange   Wow. Just buy a cheap Civic until you can do a 91...   Aug 25 2019, 08:14 PM
HansJan   I run dual carbs. I hate everything about it. It...   Aug 25 2019, 08:21 PM
- Lo-Fi Version Time is now: 22nd August 2025 - 11:18 AM
