| jdamiano |
Aug 24 2019, 02:34 PM
Member ![]() ![]() Group: Members Posts: 336 Joined: 18-March 18 From: Jacksonville Member No.: 21,981 Region Association: South East States |
I have been trying to help get a friends Creamsicle running. Was running poorly and shutting off and not starting back up till it cooled when we started. Replaced all the vacuum lines with the kit from AA and replaced the MPS with a torn diaphragm with a known good one that we leak down tested. Car runs and idles fine but now it just still shuts off and won’t start back up. We aren’t even sure temp matters. It may be random. We tightened all the grounds but still can’t get it to stay running. Once it starts it seems like it would idle forever. Try to take it around the block and we are dragging it home. We put a fuel pressure gauge in line at the drivers side rail and 30psi steady. We are thinking about swapping the entire wiring harness out with one from a car that converted to carbs. Any other suggestions??
| Rand |
Aug 24 2019, 04:38 PM
Cross Member ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 7,415 Joined: 8-February 05 From: OR Member No.: 3,573 Region Association: None |
This is why you don't throw parts at it.
jdamiano DJet trouble Aug 24 2019, 02:34 PM
BeatNavy Did you check CHT as well as the wire from CHT to ... Aug 24 2019, 03:24 PM
dr914@autoatlanta.com I agree, if the fuel pressure is steady. No reaso... Aug 24 2019, 03:27 PM
jdamiano
I agree, if the fuel pressure is steady. No reas... Aug 24 2019, 03:42 PM
BeatNavy CHT = cylinder head temp (sensor). Not ignition r... Aug 24 2019, 03:45 PM
Rand If it runs....
Can you verify the fuel pump keeps... Aug 24 2019, 04:42 PM
jdamiano
If it runs....
Can you verify the fuel pump keep... Aug 24 2019, 04:50 PM
jdamiano
If it runs....
Can you verify the fuel pump keep... Aug 24 2019, 04:54 PM
jdamiano
If it runs....
Can you verify the fuel pump keep... Aug 24 2019, 05:05 PM
rjames You said you replaced the MPS.
After replacing the... Aug 24 2019, 06:30 PM![]() ![]() |
Lo-Fi Version | Time is now: 17th June 2026 - 05:32 AM |
