> DJet trouble, What next?
jdamiano
post Aug 24 2019, 02:34 PM
I have been trying to help get a friends Creamsicle running. Was running poorly and shutting off and not starting back up till it cooled when we started. Replaced all the vacuum lines with the kit from AA and replaced the MPS with a torn diaphragm with a known good one that we leak down tested. Car runs and idles fine but now it just still shuts off and won’t start back up. We aren’t even sure temp matters. It may be random. We tightened all the grounds but still can’t get it to stay running. Once it starts it seems like it would idle forever. Try to take it around the block and we are dragging it home. We put a fuel pressure gauge in line at the drivers side rail and 30psi steady. We are thinking about swapping the entire wiring harness out with one from a car that converted to carbs. Any other suggestions??
Rand
post Aug 24 2019, 04:42 PM
Cross Member
If it runs....
Can you verify the fuel pump keeps running?
jdamiano
post Aug 24 2019, 04:54 PM
QUOTE(Rand @ Aug 24 2019, 04:42 PM) *
If it runs....
I am very good with a multi meter but I just don’t know enough about this system to know what to check for. I feel like it’s an electrical problem keeping the injectors from firing.
- Lo-Fi Version Time is now: 17th June 2026 - 06:59 AM
