| Alphaogre |
Aug 23 2019, 04:50 PM
Member ![]() ![]() Group: Members Posts: 460 Joined: 28-May 12 From: San Diego Member No.: 14,487 Region Association: Southern California |
A few weeks ago I was going down the freeway and driving just fine, then when I exited and started to drive down the road, I noticed all the sudden it would not go in any gears, not down or up, and every time I tried I would get the horrendous grinding sound.
The clutch pedal felt fine so when I pulled over I looked under thinking maybe the clutch cable loosened so it wouldn't disengage, but that was all fine. • I noticed I can get it in gear when it's off (all of them including reverse) • The car starts when it's not in gear fine, then when I try to go in gear would grind or stall immediately. • When I try to put in in gear and start it with the clutch pedal in, it would just lurch forward as if you were starting it in gear with no clutch pedal in. • Its a side shift tranny, and I haven't had any issues shifting or noise prior to this situation. My thought is maybe the throwout bearing? but someone mentioned maybe the main input shaft bearing? Id like a better idea of pinpointing the issue as it's a decision to pull the tranny, or both the motor and the tranny. As of now its back on Jack stands and waiting (IMG:style_emoticons/default/biggrin.gif) ![]() |
| rhodyguy |
Aug 26 2019, 05:16 PM
Chimp Sanctuary NW. Check it out. ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 22,252 Joined: 2-March 03 From: Orion's Bell. The BELL! Member No.: 378 Region Association: Galt's Gulch |
Look in the access hole just below the back pad too. How much pedal free play at the pedal? With the engine off. Did you double nut the cable? Check the set screws. Inspect the rear ball cup bushing while the cover is off. Takes 15 minutes. Start ruling things out.
Alphaogre Back up on Jack Stands Aug 23 2019, 04:50 PM
white1975
A few weeks ago I was going down the freeway and ... Aug 23 2019, 05:46 PM
Eliasd914 I just bout this 75 1.8 last week same problems. t... Aug 23 2019, 05:50 PM
rjames
:agree:
Try pulling the access plate behind ... Aug 23 2019, 07:39 PM
theer I’d guess it’s the clutch cable rather than a ... Aug 23 2019, 08:07 PM
Alphaogre Would the clutch feel the same as it would when it... Aug 26 2019, 12:42 PM
jsaum Check the clutch tube. Aug 26 2019, 12:47 PM
SirAndy Check the clutch tube.
:agree:
Probably broken... Aug 26 2019, 01:19 PM
worn
Look in the access hole just below the back pad t... Aug 26 2019, 07:03 PM
mepstein Did you locktight the cone screw? Aug 26 2019, 07:07 PM![]() ![]() |
Lo-Fi Version | Time is now: 7th December 2025 - 07:16 PM |
