Compression ratio for 2056, While i am at it |
worn |
Aug 22 2019, 08:20 PM
can't remember Group: Members Posts: 3,163 Joined: 3-June 11 From: Madison, WI Member No.: 13,152 Region Association: Upper MidWest |
Pulled the motor after several years of service from the 2056 build. Two problems have plagued me. The reason i pulled the engine was to seal persistent oil leaks. I am going after the oil pump and some gaskets and seals. The second problem has always been cylinder head temps. They are kinda high. I built the motor to have a 9.0:1 compression ratio, which works in my cast iron block, water cooled TR6. On further consideration, that may be a tad high. Especially after a few hours of highway driving in the summer.
The internet has lots of calculators to do the math. I can get or may already have cylinder shims. What ought it to be? The goal is dependable gobbling of miles with some increased power due a 2056. Suggested ratios? Guess i should have asked this question some time ago. Thanks folks. You are great. |
Mark Henry |
Aug 24 2019, 11:05 AM
Web #73 cam a 8.5 CR is about the max, make sure to check both sides. You can stack base shims, 3 max.
Big engines, oversize intake/exhaust, large duration (overlap) carb cams (or aftermarket FI) are the ones that can run higher CR. |
worn |
Aug 28 2019, 08:16 PM
Web #73 cam a 8.5 CR is about the max, make sure to check both sides. You can stack base shims, 3 max. Big engines, oversize intake/exhaust, large duration (overlap) carb cams (or aftermarket FI) are the ones that can run higher CR. Thanks. I probably should mill thespigots, but don’t want to split the case. Deck heights on one side are about 0.010 different between sides. Is it ok to use shims under the cylinders to even things up? Have to re-read the Wilson book again. |
Lo-Fi Version | Time is now: 8th June 2024 - 02:49 PM |
