turnaround89 |
Senior Member ![]() ![]() ![]() Group: Members Posts: 671 Joined: 17-May 08 From: Rockford, Illinois Member No.: 9,067 Region Association: Upper MidWest ![]() |
Hi everyone, so December 2018 was the first time I got to hear the WRX STi motor I purchased run. It ran rough because the intake wasn't connected, hardly any sensors hooked up, etc. However, it ran and that made me happy knowing my investment wasn't useless.
The engine that was purchased is supposed to be a subaru wrx gc8 sti v4 turbo ej20 Cut to a few months later, now I have all the required sensors (MAF, purge solenoid, ignitor, etc) that I was missing purchased and hooked up. Vacuum hoses hooked up and I thought now the engine should run and idle beautifully. Nope, it will fire and run for maybe 3 seconds then shut off. Check out the video in the link. Subaru Engine Video The only thing I dont have hooked up are to the non-pressure side of the intake. I tried plugging these holes today and the car did t idle any better. Now, I need to find a permanent solution to these holes, but I swear the engine is running worse now with everything hooked up then in December with nothing hooked up. Any ideas where I could start? I was thinking fuel pressure and timing would be my next step. In the video you can hear the fuel pump prime the system before the engine kicks over. The wiring harness was sent out to iwire services to be redone and that appears to be functioning properly. Thank you everyone for your help. |
turnaround89 |
No worries 76-914
It appears the idle air control valve is working. The video link below shows it moves upon powering up the ECU. Idle Air Control Valve Here are the connectors that are on the ECU. The yellow one should be the SSM, not really sure what the large gray/green one is. im nkt sure what the little white and green connectors in the second picture are for but was told to leave them alone by the company that did the wiring harness. (IMG:http://www.914world.com/bbs2/uploads_offsite/i.imgur.com-9067-1567277062.1.jpg) (IMG:http://www.914world.com/bbs2/uploads_offsite/i.imgur.com-9067-1567277063.2.jpg) I believe i need to purchase the cable in the link below to attach to the SSM on the ECU. Anyone familiar with Evoscan? Evoscan SSMI |
Lo-Fi Version | Time is now: 5th September 2025 - 08:04 AM |
