| bbrock |
Sep 1 2019, 07:05 PM
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 5,269 Joined: 17-February 17 From: Montana Member No.: 20,845 Region Association: Rocky Mountains
This is a pretty specific question but wondering if anyone has experience or thoughts on PPG K36 vs. K38 primer surfacers. In reading other forums, it seems some people think that because K38 is a high build surfacer, it has a higher solids content and therefore less shrink back. Local shop stocks K36 but has to order K38 which is also more expensive.
Would one month sitting in the sun be enough time for either of these to shrink before blocking, seal, and finish coat? I realize there are probably cheaper options that are just as good but I'm pretty limited on what is available at the local paint shop and want to keep all the products in the same paint family since I'm a novice at this. TIA. |
| roblav1 |
Sep 2 2019, 07:22 AM
Senior Member ![]() ![]() ![]() Group: Members Posts: 528 Joined: 18-September 12 From: KY Member No.: 14,943 Region Association: MidAtlantic Region |
It was definitely easier spraying lacquer back in the day... more forgiving.
On the K36, I start with 180 or 220 dry in an orbital and/or straight line sander, just to get it somewhat smooth... because K36 is a lot harder than the old lacquer primer surfacer. Then I wet block sand with 220, then 400, then 600. K36 will actually sheen a bit with 600 wet. K36 spec sheet says 4 hours to sand after spray. I found that using no reducer in the first coats is OK. But highly recommend a 5:1:1 ratio with reducer on final K36 coats. It was less splotchy when I tried my old siphon gun once, but overspray was pretty bad. So I reverted back to the HVLP. The reason I use black DP90LF is that I can see it easier if I start to sand through the K36. And I also use the DP90LF on almost everything on the car that should be black... like suspension, rockers, engine lid, etc. Today is sanding day on the hoods, engine lid, and eyebrows... with a small bit of filler here and there. Good luck! |
bbrock PPG Primer Surfacer Sep 1 2019, 07:05 PM
worn
This is a pretty specific question but wondering ... Sep 1 2019, 07:33 PM
roblav1 I've had good luck with K36, especially over D... Sep 1 2019, 07:48 PM
bbrock Thanks! Yes, I'll be spraying it over DP5... Sep 1 2019, 09:06 PM
bbrock :bump:
Bumping this up since it posted over a hol... Sep 13 2019, 08:45 AM
roblav1 No idea of shrink time, and I've never worried... Sep 13 2019, 04:51 PM
Mark Henry High build primer surfacer should never be used as... Sep 15 2019, 06:33 AM
twistedstang
High build primer surfacer should never be used a... Sep 15 2019, 09:42 AM
mb911 :agree: kind of sort of.. I cant tell you that ... Sep 15 2019, 11:55 AM
bbrock Okay, so the people complaining about shrinking on... Sep 15 2019, 12:00 PM![]() ![]() |
Lo-Fi Version | Time is now: 3rd March 2026 - 10:24 PM |
