| annyung |
Aug 5 2019, 07:35 PM
Newbie ![]() Group: Members Posts: 5 Joined: 15-June 19 From: Detroit Member No.: 23,217 Region Association: Upper MidWest |
So here goes nothing. I'm kicking off my build for a 400+hp awd electric conversion of my 74 914. I will part out a Volt and use the drive unit in the rear of the car, the battery will be rotated 180 and go in the tunnel between the seats. A Model S drive unit will power the front wheels completing the AWD.
| 914forme |
Sep 4 2019, 06:23 PM
Times a wastin', get wrenchin'! ![]() ![]() ![]() ![]() Group: Members Posts: 3,899 Joined: 24-July 04 From: Dayton, Ohio Member No.: 2,388 Region Association: None
Are you running the Volt generation unit also? I would be down with that one. I have only seen one but there is a volt running around that has a diesel powered generation unit. Last time I saw it pop up, it was getting a true 126 Mpg, think diesel locomotive, very same concept.
As for all the stuff, all he needs down the center tunnel is the batteries, everything else can be ran out the logs if need be. A 5 gallon fuel cell will get you a pretty far piece as the volt is a hybrid, and the Bolt was the true electric. Best of luck with the build, your resume suggests you can work out the drive sync issue with a bit of software and a controller. Couple of wheel sensors or flange sensors and you could sync them up no issue. (IMG:style_emoticons/default/popcorn[1].gif) BTW if you look at two builds on here your center tunnel should not be an issue, and you will actually increase rigidity if done correctly. Thanks for the update and carry on. (IMG:style_emoticons/default/welcome.png) |
annyung 74 Electric Build Thread Aug 5 2019, 07:35 PM
annyung My 74 914 2.0 I picked up for $3400. It was a... Aug 5 2019, 07:40 PM
SirAndy How are you going to synchronize the two engines?
... Aug 5 2019, 07:42 PM
annyung The 2013 Volt with parts only title I will use the... Aug 5 2019, 07:44 PM
Valy I would just add more batteries instead of the fro... Aug 5 2019, 08:09 PM
Mike Bellis :wttc:
Another great project that will sell in 20... Aug 5 2019, 08:23 PM
thelogo Lots of battery and 2 drive units
Better build ou... Aug 5 2019, 08:39 PM
burton73 Welcome to the world
I have seen some people here... Aug 5 2019, 08:58 PM
ChrisFoley
I have seen some people her... Aug 7 2019, 05:17 AM
Chi-town After seeing first hand what happens to a 914 when... Aug 5 2019, 09:05 PM
thelogo
After seeing first hand what happens to a 914 whe... Aug 6 2019, 12:11 PM
Chris914n6
After seeing first hand what happens to a 914 whe... Aug 6 2019, 02:28 PM
Andyrew As an engineering feat it's going to be cool t... Aug 5 2019, 10:00 PM
bbrock I also like this project. Love the can-do spirit.... Aug 7 2019, 07:53 AM
rbzymek
I also like this project. Love the can-do spirit... Aug 8 2019, 11:57 AM
burton73 As the First one on 914 world to own a Tesla S (as... Aug 8 2019, 02:19 PM
90quattrocoupe Good luck.
I learned a long time ago, that if you ... Aug 8 2019, 03:14 PM
annyung Dropped the drive unit/generator from the Volt.
Sep 3 2019, 10:00 PM
annyung Battery dropped as well. Time to get the shoe horn... Sep 3 2019, 10:03 PM
Carl La Fong Interestingly, Porsche has just introduced their f... Sep 4 2019, 06:36 PM
bandjoey Let's see....is it the red wire or the blue wi... Sep 4 2019, 10:40 PM
burton73 Electric Porsche
The hub-mounted electric motors... Sep 6 2019, 11:15 AM
FourBlades Good luck with the build. :first:
Folks on this... Sep 7 2019, 09:23 AM
cali914 0 to 60 will be 1 second hahahahahaha. I love it w... Sep 7 2019, 09:30 AM
914forme I would recommend the 914LTD kit to re-enforce the... Sep 7 2019, 07:48 PM
euro911 We acquired a fleet of VW Rabbit pick-up trucks fo... Sep 7 2019, 08:32 PM![]() ![]() |
Lo-Fi Version | Time is now: 28th April 2026 - 01:35 PM |
