Ratrod87 |
Member ![]() ![]() Group: Members Posts: 69 Joined: 4-September 19 From: Ft Mitchell Alabama Member No.: 23,429 Region Association: None ![]() |
Hello everyone I was hoping someone in this awesome community could help me diagnose and transmission or shifter problem. I recently within the last 24hrs made a deal on a 71 porsche 914 and have yet to get it home but I already know the car is stuck in 1st gear. The previous owner thinks something on the shifter has broke or come loose and doesn't think it's the transmission. I have never worked on a porche 914 so can someone tell me what I need to look for. I have very good mechanical skills and even have a well outfitted personal shop with a two post lift which leads me to my second question. (Is it safe to lift this car with a two post lift? The car appears to be solid and rust free except for the hell hole .) Any help or advice would be much appreciated. I also have a great sense of humor if anyone wants to roast a greenhorn....
Attached thumbnail(s) ![]() |
rhodyguy |
Chimp Sanctuary NW. Check it out. ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 22,098 Joined: 2-March 03 From: Orion's Bell. The BELL! Member No.: 378 Region Association: Galt's Gulch ![]() |
Buy a Haynes manual. The diagrams are very informative. The tail shift linkage has more areas for shifting issues than the side shift. Be aware of the rolled pin at the rear of the trans above the access plate. You will have to drain the gear lube first to inspect it. Make sure to remove the fill plug before draining.
Ratrod87 |
Buy a Haynes manual. The diagrams are very informative. The tail shift linkage has more areas for shifting issues than the side shift. Be aware of the rolled pin at the rear of the trans above the access plate. You will have to drain the gear lube first to inspect it. Make sure to remove the fill plug before draining. Thank you, I will definitely do that right now, it's probably a good thing to have. Thank you for your advice |
Lo-Fi Version | Time is now: 17th June 2024 - 09:34 PM |
