| enf2232 |
Sep 9 2019, 05:52 PM
Member ![]() ![]() Group: Members Posts: 93 Joined: 13-July 14 From: Toledo, OH Member No.: 17,621 Region Association: None |
Pedal went to the floor and did not return. Removed carpet to be sure it was not hanging up. Disconnected pedal from linkage and there is no resistance in the mechanism. Where to start? Pedal cluster? Accelerator cable? Other? Novice at best when it comes to mechanical experience.
Pics added |
| Mikey914 |
Sep 9 2019, 07:08 PM
The rubber man ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 12,784 Joined: 27-December 04 From: Hillsboro, OR Member No.: 3,348 Region Association: None
Check to see if the throttle cable came out or your missing a spring. The natural resilience of the rubber is not enough to return on it's own.
enf2232 Accelerator Pedal (need more help) Sep 9 2019, 05:52 PM
partwerks I'd look in the back. Sep 9 2019, 05:57 PM
Rusty 1. Check the throttle cable at the engine side. I... Sep 9 2019, 05:57 PM
enf2232
Check to see if the throttle cable came out or yo... Sep 22 2019, 11:25 AM
enf2232 Finally had a chance to get back on it. Pulled th... Sep 22 2019, 11:21 AM
enf2232 Some photos Sep 22 2019, 12:04 PM
rjames Check spring l #33 in the parts diagram above. Sep 22 2019, 02:52 PM
914werke :agree: When the pedal cluster spring gives it up ... Sep 22 2019, 03:07 PM
enf2232 That part is labeled "spring for clutch pedal... Sep 22 2019, 04:06 PM
phatnine11 enf2232,
Just a question, I don't see a spring... Sep 22 2019, 04:25 PM
worn
enf2232,
Just a question, I don't see a sprin... Sep 22 2019, 05:58 PM
worn
enf2232,
Just a question, I don't see a spri... Sep 22 2019, 05:59 PM
enf2232 I didn't see one either and this is the first ... Sep 22 2019, 05:56 PM
enf2232 Partial success. Removed air cleaner and searched... Sep 24 2019, 05:04 PM
ClayPerrine The later 914s had a secondary throttle spring wou... Sep 25 2019, 07:08 AM![]() ![]() |
Lo-Fi Version | Time is now: 12th September 2026 - 12:22 AM |
