| partwerks |
Sep 8 2019, 05:21 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,642 Joined: 7-September 06 From: Grand Island, NE Member No.: 6,787 |
| BIGKAT_83 |
Sep 9 2019, 07:22 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,800 Joined: 25-January 03 From: Way down south Bogart,GA Member No.: 194 Region Association: South East States
Its going to be real low when those rear mounts pull thru. They need the factory washer on the top side of the bolt.
| partwerks |
Sep 9 2019, 07:27 PM
Its going to be real low when those rear mounts pull thru. They need the factory washer on the top side of the bolt. I just have smaller flat washers on the upper trans mounts, and so are you saying that I need washers with a bigger outside diameter so that it doesn't sag? |
partwerks Axle angle Sep 8 2019, 05:21 PM
bdstone914 That rear end must be sitting very low. Badly gagg... Sep 9 2019, 05:31 AM
914Sixer Looks like aftermarket springs with spacer blocks. Sep 9 2019, 05:56 AM
wndsrfr
Looks like aftermarket springs with spacer blocks... Sep 9 2019, 06:35 AM
partwerks So maybe need new springs? Sep 9 2019, 06:04 AM
bdstone914
Hard to say. How does the car sit ? Cant see th... Sep 9 2019, 06:34 AM
Andyrew Can we see some pics of your trans mount and the s... Sep 9 2019, 09:17 AM
SirAndy Actually looks like the transmission is much lower... Sep 9 2019, 10:16 AM
Andyrew Ya I think the trans is falling off the hangers. P... Sep 9 2019, 10:19 AM
partwerks Maintenace guy at work, and I made a new trans mou... Sep 9 2019, 05:23 PM
SirAndy Your transmission should be a good 2" higher ... Sep 9 2019, 05:29 PM
partwerks
Your transmission should be a good 2" higher... Sep 10 2019, 06:06 PM
partwerks
Your transmission should be a good 2" higher... Sep 11 2019, 08:30 PM
SirAndy Also, why are your adjustable shocks all the way u... Sep 9 2019, 05:32 PM
partwerks
Also, why are your adjustable shocks all the way ... Sep 9 2019, 05:36 PM
Also, why are your adjustable shocks all the way... Sep 9 2019, 06:21 PM
partwerks
[quote name='partwerks' post='2745633' date='Sep ... Sep 9 2019, 07:14 PM
BIGKAT_83 This is what you need on the top of mount.
This ... Sep 9 2019, 08:03 PM
partwerks
Do... Sep 9 2019, 08:07 PM
Andyrew
D... Sep 10 2019, 07:53 PM
euro911 [quote name='partwerks' post='2745686' date='Sep 9... Sep 23 2019, 09:15 PM
partwerks
[quote name='partwerks' post='2745686' date='Sep ... Sep 23 2019, 09:53 PM
partwerks
[quote name='partwerks' post='2745686' date='Sep ... Sep 24 2019, 07:15 PM
euro911 This is what it should look like
http://www.914wo... Sep 10 2019, 08:35 PM
euro911 I just noticed you're not running a 901 trans ... Sep 11 2019, 11:09 PM
partwerks I wonder if the adapter plate could be made with a... Sep 12 2019, 06:05 AM
Andyrew
I wonder if the adapter plate could be made with ... Sep 12 2019, 09:02 AM
euro911 I wonder if the adapter plate could be made with a... Sep 13 2019, 12:40 PM
euro911 From my trans to my wheels, my axles go uphill at ... Sep 12 2019, 01:57 PM
partwerks
From my trans to my wheels, my axles go uphill at... Sep 13 2019, 08:51 AM
partwerks
Looks like at the top of that adapter plate... Sep 13 2019, 01:35 PM
partwerks These shocks and springs are at least 13 years old... Sep 13 2019, 07:34 PM
Andyrew
These shocks and springs are at least 13 years ol... Sep 13 2019, 07:42 PM
partwerks
These shocks and springs are at least 13 years o... Sep 13 2019, 07:53 PM
partwerks RE: Axle angle Sep 15 2019, 05:47 PM
Andyrew It's low but I've seen lower. I say modify... Sep 15 2019, 08:15 PM
Krieger I love that color! Sep 16 2019, 08:20 AM
partwerks
I love that color!
Thanks.
It was originall... Sep 16 2019, 06:20 PM
76-914 You can pick up another 2" if you delete the ... Sep 16 2019, 09:20 AM
partwerks Will putting on new springs help with the angle on... Sep 23 2019, 05:43 AM
Andyrew
Will putting on new springs help with the angle o... Sep 23 2019, 07:38 AM
euro911 The stance (ride height) of your car looks fine. I... Sep 23 2019, 01:56 PM
partwerks
The stance (ride height) of your car looks fine. ... Sep 23 2019, 07:18 PM
euro911 Certain things need to be identified. Is it an al... Sep 25 2019, 05:16 PM
partwerks Got it on the hoist, for a few better pictures.
... Sep 25 2019, 06:44 PM
euro911 Can you shorten the upright sections of the trans ... Sep 25 2019, 07:51 PM
partwerks
Can you shorten the upright sections of the trans... Sep 25 2019, 08:12 PM
partwerks
Can you shorten the upright sections of the trans... Sep 27 2019, 09:07 PM
euro911 Can you shorten the upright sections of the trans ... Sep 28 2019, 03:59 AM
partwerks
[quote name='partwerks' post='2750756' date='Sep ... Sep 28 2019, 08:11 AM
euro911 Not sure how heavy of springs are in there, but wo... Sep 28 2019, 11:50 AM
ClayPerrine
[quote name='euro911' post='2750189' date='Sep 25... Sep 28 2019, 08:04 PM
Mike Bellis Based on what I see, you have a compound angle lik... Sep 27 2019, 10:33 PM
partwerks
Based on what I see, you have a compound angle li... Sep 27 2019, 10:39 PM
Mike Bellis Drive it a few hundred miles and check to see if t... Sep 27 2019, 10:41 PM
euro911 Wow, well thought-out design, Clay.
:first: Sep 29 2019, 02:57 PM
jimkelly enjoyed your pics. thanks. Oct 5 2019, 07:10 PM![]() ![]() |
Lo-Fi Version | Time is now: 10th November 2026 - 01:23 AM |
