> Jake Raby: Cooling system testing, reichert tuning?
Aaron Cox
post Nov 28 2004, 01:48 PM
Professional Lawn Dart
title says it all, have you tried the horizontal fan system from reichert? at the autocross, saw a guy running this setup on a 2.7L type IV monster...
looked cool...but does it cool?
Reiche
post Dec 3 2004, 01:06 PM
QUOTE(Jake Raby @ Dec 3 2004, 10:37 AM)
All in all:
Air volume and velocity are not just the key...
Pressure is not just the key..
The key is the perfect mix of both, and finding that mix is not cheap or easy. It will drive a person insane.
Yeah it's never just one thing. It's about finding the compromises made by the original engineers and trying to figure out why they were made. Worse, they often have to do with factors outside the cooling system itself like the engine power, fuel grades, rpm range, expected operating conditions, cost factors, etc. etc. Coming up with a solution that can accommodate every reasonably foreseeable condition inevitably results in something that works for most but is good for none.
So no wonder it drives you crazy: it's one person against a whole team of engineers and designers, not to mention executives and accountants.
We got your back though.
Aaron Cox   Jake Raby: Cooling system testing   Nov 28 2004, 01:48 PM
Elliot Cannon   Isn't that the one that goes from a verticle p...   Nov 28 2004, 01:54 PM
Aaron Cox   thats what ive been reading....   Nov 28 2004, 02:01 PM
Carrera916   Reichert fan? The electric one? Do you have a webs...   Nov 28 2004, 03:10 PM
Aaron Cox   belt drive... crank pullry to 90 degree pully to f...   Nov 28 2004, 03:13 PM
nebreitling   i agree! it seems like an electric fan (or tw...   Nov 28 2004, 03:14 PM
Aaron Cox   http://www.ismi.net/riecherttuning/ibr18.jpg http:...   Nov 28 2004, 03:18 PM
synthesisdv   here is one electric setup I have seen. don't...   Nov 28 2004, 03:29 PM
synthesisdv   more found... I have also seen a rig with one big...   Nov 28 2004, 03:34 PM
Dominic   <...   Dec 2 2004, 12:43 PM
Jake Raby   You'll never understand it that way! I tho...   Dec 2 2004, 02:43 PM
lapuwali   Pressure is generated by volume trying to move thr...   Dec 2 2004, 03:49 PM
Jake Raby   And thats why 911 fans belong on 911 engines- they...   Dec 2 2004, 04:00 PM
Reiche   Thanks for the answers guys and sorry for the thre...   Dec 3 2004, 12:12 PM
Jake Raby   The stock 914 system needs restriction under the c...   Dec 3 2004, 12:37 PM
Britain Smith   I got Type-1 tins like you suggested and they are ...   Dec 3 2004, 12:52 PM
Jake Raby   Yep, they are just flat... Thats the key, you don...   Dec 3 2004, 12:57 PM
Reiche   ...   Dec 3 2004, 01:06 PM
Jake Raby   They weren't making 50HP per cylinder and stil...   Dec 3 2004, 01:10 PM
Mueller   that is why water cooling is better !!...   Dec 3 2004, 01:11 PM
Britain Smith   ...   Dec 3 2004, 01:28 PM
Mark Henry
  Dec 3 2004, 01:33 PM
Britain Smith     Dec 3 2004, 01:37 PM
Mark Henry   With the 911 type I don't know which deflector...   Dec 3 2004, 01:41 PM
Britain Smith   As Jake knows, I also have the advantage to be run...   Dec 3 2004, 01:44 PM
Mark Henry   Don't matter. BTW me too!   Dec 3 2004, 01:49 PM
- Lo-Fi Version Time is now: 15th July 2025 - 01:17 AM
