| Ratrod87 |
Sep 9 2019, 08:35 PM
Member ![]() ![]() Group: Members Posts: 69 Joined: 4-September 19 From: Ft Mitchell Alabama Member No.: 23,429 Region Association: None |
Hello everyone my name is Jerry also known to some as (newbie hoser scammer ) I recently within the past few days purchased our first 914 . I immediately fell in love with the car at first sight along with my two sons age 9 and 18. I was very nervous about purchasing a car that I knew nothing about, with that said the car arrived today and I had already prepared myself for disappointment because in the past every time I bought a project car it turns out to be way worse than I thought. I'm pleased to say this car did not disappoint me. I immediately started looking the car over expecting to find rotted floors and rockers , quarters or something. I pulled the trunk carpets out and no visible rust. I poked around with a screw driver and nothing. I scraped under coating off in the wheel well and corners thinking I'll definitely find rust there but nothing. I haven't pulled the rocker covers off yet so there is still a chance. The only place with rust was below the battery which didn't even look that bad, the dreaded hell hole was the only spot I could find so far and didn't look as bad as I thought.
| ClayPerrine |
Sep 10 2019, 07:55 AM
Life's been good to me so far..... ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Admin Posts: 16,568 Joined: 11-September 03 From: Hurst, TX. Member No.: 1,143 Region Association: NineFourteenerVille
You have a great starting point. Most people find lots more rust than that. Build a 2056 with D-Jet and install it. That is the most bang for the buck in the Type IV builds. The transmission probably sheared the roll pin on the side shifter console. It happened to us years ago. Easy fix, but you have to drain the gear oil and pull the shift console. Suspension upgrades would be a set of sway bars, new springs and shocks. and some wider tires. The rest of the car looks great. Wonderful find! |
| Ratrod87 |
Sep 10 2019, 08:04 AM
(IMG:style_emoticons/default/welcome.png) You have a great starting point. Most people find lots more rust than that. Build a 2056 with D-Jet and install it. That is the most bang for the buck in the Type IV builds. The transmission probably sheared the roll pin on the side shifter console. It happened to us years ago. Easy fix, but you have to drain the gear oil and pull the shift console. Suspension upgrades would be a set of sway bars, new springs and shocks. and some wider tires. The rest of the car looks great. Wonderful find! What's your thoughts on the steel fender flares, I want to keep the car as original as possible but my son likes the flares and sportier look. Would doing that take away from the car? |
| ClayPerrine |
Sep 10 2019, 08:31 AM
(IMG:style_emoticons/default/welcome.png) You have a great starting point. Most people find lots more rust than that. Build a 2056 with D-Jet and install it. That is the most bang for the buck in the Type IV builds. The transmission probably sheared the roll pin on the side shifter console. It happened to us years ago. Easy fix, but you have to drain the gear oil and pull the shift console. Suspension upgrades would be a set of sway bars, new springs and shocks. and some wider tires. The rest of the car looks great. Wonderful find! What's your thoughts on the steel fender flares, I want to keep the car as original as possible but my son likes the flares and sportier look. Would doing that take away from the car? What I always say is "You have to live with the car. Do what you like to it." I have flares on my 914-6 conversion, my wife doesn't have them on her 914 1.8L. Our six is original, and is not flared. If you add the flares, you need wider tires and rims. That means bigger brakes. And that means a 5 lug conversion. Be careful... its a slippery slope. I should know...... (IMG:style_emoticons/default/biggrin.gif) |
Ratrod87 Newbie hoser scammer pics Sep 9 2019, 08:35 PM
Ratrod87 I removed the carpets in the trunk to check condit... Sep 9 2019, 08:39 PM
Ratrod87 I removed most of the stuff in the forward trunk a... Sep 9 2019, 08:43 PM
Ratrod87 I'm trying to figure out how to post more pict... Sep 9 2019, 08:45 PM
Ratrod87 I'm still trying to learn how this stuff works Sep 9 2019, 08:50 PM
Minerva's 914 So far look very GOOD. Let's see some pics of ... Sep 9 2019, 08:53 PM
Ratrod87
So far look very GOOD. Let's see some pics of... Sep 9 2019, 09:06 PM
jagalyn Nice looking car... Nice purchase. Sep 9 2019, 09:18 PM
Ratrod87
Thank you, I... Sep 9 2019, 09:21 PM
SirAndy I'm trying to figure out how to post more pict... Sep 9 2019, 09:50 PM
Ratrod87 Here is the spot under the battery Sep 9 2019, 09:48 PM
Ratrod87 This is on the very bottom of car directly beneath... Sep 9 2019, 09:52 PM
This is on the very bottom of car directly beneat... Sep 9 2019, 11:24 PM
gereed75 Bingo...... jackpot! Sep 9 2019, 09:52 PM
Ratrod87 I believe this would be a side shift transmission.... Sep 9 2019, 09:55 PM
Ratrod87 The forward trunk appears to be rust free. I poked... Sep 9 2019, 09:57 PM
Ratrod87 Looks like it has a small oil leak. But everything... Sep 9 2019, 09:59 PM
Ratrod87 The previous owner had this 2.0 bus motor built an... Sep 9 2019, 10:07 PM
Ratrod87 Every project I had ever built has had some form o... Sep 9 2019, 10:10 PM
Ratrod87 The car came with a pile of Haynes manuals and sev... Sep 9 2019, 10:15 PM
Ratrod87 The rubber bumper pads are starting to crack a lit... Sep 9 2019, 10:18 PM
Mikey914
The rubber bumper pads are starting to crack a li... Sep 10 2019, 03:27 AM
AZBanks
The rubber bumper pads are starting to crack a l... Sep 11 2019, 08:29 AM
Ratrod87
[quote name='Mikey914' post='2745762' date='Sep 1... Sep 11 2019, 08:51 AM
SirAndy This should be mandatory reading for anyone:
http:... Sep 9 2019, 11:26 PM
porschetub As mentioned don't lift on there,clean car but... Sep 10 2019, 12:40 AM
Cairo94507 Looks like a pretty clean 914 you got there. Nice... Sep 10 2019, 05:39 AM
BeatNavy Car looks surprisingly clean except for that jack ... Sep 10 2019, 05:54 AM
76-914 Welcome to the madness. :beer2: Sep 10 2019, 06:17 AM
rhodyguy If your son had to pay for the flared look (and al... Sep 10 2019, 09:04 AM
dr914@autoatlanta.com yes the car looks very good, too good to be abused... Sep 10 2019, 09:21 AM
FlacaProductions You found some nearly antique parts catalogs, too ... Sep 10 2019, 09:48 AM
Larmo63 Fix the rusted out longitudinal, get the transmiss... Sep 10 2019, 10:21 AM
Tdskip
Fix the rusted out longitudinal, get the transmis... Sep 10 2019, 10:26 AM
Ratrod87
Fix the rusted out longitudinal, get the transmis... Sep 10 2019, 12:33 PM
Bartlett 914
Fix the rusted out longitudinal, get the transmis... Sep 10 2019, 02:26 PM
Garland I noticed this in your post, that’s a good two ... Sep 10 2019, 10:34 AM
Ratrod87
I noticed this in your post, that’s a good two... Sep 10 2019, 12:34 PM
Rob-O I think all of the above is sound advice.
I love ... Sep 10 2019, 07:13 PM
Ratrod87
I love... Sep 10 2019, 09:34 PM
Larmo63 Try looking here at some threads on 914s that peop... Sep 10 2019, 09:58 PM![]() ![]() |
Lo-Fi Version | Time is now: 6th November 2026 - 12:22 AM |
