> steering wheel, 1974 914 1.8............removal
brcacti
post Sep 10 2019, 12:59 PM
Hello, is there a video or directions how to remove momo steering wheel and stock steering wheel, want to fix blinker and MIGHT put stock wheel back on, which wheel do you all prefer?
post Sep 10 2019, 01:26 PM
914-6 GT in waiting
I like stock. Unscrew the nut a couple turns but leave a couple turns threaded. I’m pretty sure it’s a 25mm. Pull the wheel to break it loose. Leaving the nut loose on the shaft will keep it from m hitting you in the face if it requires a lot of force to remove. You can tap the back of the rim with a rubber mallet to get it started.
Don’t use the steering lock to hold the wheel when you remove the nut. It’s not meant for that much force.
- Lo-Fi Version Time is now: 21st September 2026 - 03:12 PM
