| brcacti |
Sep 10 2019, 12:59 PM
1974 914 1.8 ![]() ![]() ![]() Group: Members Posts: 674 Joined: 17-July 19 From: PHX AZ 60 miles south Member No.: 23,302 Region Association: Southwest Region |
Hello, is there a video or directions how to remove momo steering wheel and stock steering wheel, want to fix blinker and MIGHT put stock wheel back on, which wheel do you all prefer?
| Valy |
Sep 10 2019, 04:30 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,677 Joined: 6-April 10 From: Sunnyvale, CA Member No.: 11,573 Region Association: Northern California |
Unscrew the center nut all the way and mark the steering wheel and axis position with a Sharpie.
Put the nut back but leave 1-2 turns of. Pull the wheel and tap on the axis. 2 people will get it out in 5 seconds. Single handed you need to change the holding position while you tap. Really easy. Use the mark to match alignment when fitting back (same wheel). If replacing wheel, try to make the mark at an angle that's easy to transfer to the new wheel. |
brcacti steering wheel Sep 10 2019, 12:59 PM
mepstein I like stock. Unscrew the nut a couple turns but l... Sep 10 2019, 01:26 PM
brcacti
I like stock. Unscrew the nut a couple turns but ... Sep 10 2019, 02:24 PM
brcacti Thanks for the no wheel in face information good i... Sep 10 2019, 02:28 PM
I like stock. Unscrew the nut a couple turns but... Sep 10 2019, 02:30 PM
Garland If you’ve ever noticed when the wheels attached ... Sep 10 2019, 02:37 PM
Valy If you use a non-stock steering wheel, don't f... Sep 10 2019, 04:32 PM
brcacti I think only one side does not auto cancel but yes... Sep 10 2019, 05:37 PM
I think only one side does not auto cancel but ye... Sep 10 2019, 05:49 PM
brcacti Ok thanks a lot, so I will do both the canceling c... Sep 10 2019, 06:02 PM
Valy Yes, the wheel needs to come off to replace both s... Sep 10 2019, 09:27 PM
brcacti Thanks to all who gave information Sep 11 2019, 05:30 AM
mepstein I was thinking the turn signal replacement is a pi... Sep 11 2019, 06:31 AM
Valy
I was thinking the turn signal replacement is a p... Sep 11 2019, 09:05 AM
FlacaProductions @[url=http://www.914world.com/bbs2/index.php?showu... Sep 11 2019, 09:57 AM
Valy
@[url=http://www.914world.com/bbs2/index.php?show... Sep 11 2019, 11:05 AM![]() ![]() |
Lo-Fi Version | Time is now: 21st September 2026 - 03:13 PM |
