> Newbie hoser scammer pics, The 914 has arrived
Ratrod87
post Sep 9 2019, 08:35 PM
Hello everyone my name is Jerry also known to some as (newbie hoser scammer ) I recently within the past few days purchased our first 914 . I immediately fell in love with the car at first sight along with my two sons age 9 and 18. I was very nervous about purchasing a car that I knew nothing about, with that said the car arrived today and I had already prepared myself for disappointment because in the past every time I bought a project car it turns out to be way worse than I thought. I'm pleased to say this car did not disappoint me. I immediately started looking the car over expecting to find rotted floors and rockers , quarters or something. I pulled the trunk carpets out and no visible rust. I poked around with a screw driver and nothing. I scraped under coating off in the wheel well and corners thinking I'll definitely find rust there but nothing. I haven't pulled the rocker covers off yet so there is still a chance. The only place with rust was below the battery which didn't even look that bad, the dreaded hell hole was the only spot I could find so far and didn't look as bad as I thought.
Rob-O
post Sep 10 2019, 07:13 PM
I think all of the above is sound advice.
I love that color (looks like Tangerine). If it were me I’d get The car operational first and then make a list of projects to tackle. I agree with Clay that the roll pin inside the trans is your most likely culprit. An easy job. Pull the long shift rod at the firewall and at the transmission. Drain the transmission. But make sure you can loosen the top trans fill plug before you loosen and drain the trans fluid. More than a few of us have pulled the bottom plug on the trans to drain it only to realize that they could t get the top plug off, leaving them no way to refill the transmission with fluid. Once the transmission is drained pull the shift console. I believe it’s just two 10mm or two 13mm bolts holding it in. The shift rod on that console that goes into the transmission has a ‘finger’ on it that engages the gears. The finger is held onto that shift rod inside the transmission with a small roll pin that goes through the rod and the finger. If it’s all in one piece you can tilt the whole console to get it out. If the shift finger has sheared the pin the console will come out pretty easily and the finger should fall out after it. Hopefully the pin parts fall out, too.
Inspect and see what’s needed. There are some seals to replace while you’re in there to help prevent leaks. I’d also check the bushings that the long shift rod rides in on the shifter console and replace. Cheap part but helps shift feel. Also there are bushings at the front of the shift rod. I’m assuming that since you have a side shifter trans that the front of the shift rod has the late style shift knuckle. That can be disassembled and the bushings replaces (search the site of how to do this without breaking the aluminum cage). Then go for a short drive...you’ll get a feel for what needs to get repaired. But get those rusted areas repaired quickly. Lots of help here and probably several people in your area here on the board willing to lend a hand.
On a side note the 914 is incredibly blessed on the amount of parts that are available. Very, very few parts are unavailable. For instance you asked about the rubber bumper tops being available. The guy that replied that yes they were? Yeah, he’s the guy that makes them...and about a million other parts for the 914. You can visit his site (www.914rubber.com) but prepare your wallet to be decimated in short order.
Ratrod87
post Sep 10 2019, 09:34 PM
QUOTE(Rob-O @ Sep 10 2019, 07:13 PM) *
Thank you for the information about the shifter, my two sons are excited about getting to work on the car this weekend. My oldest son came home today from work and started taking the seats out to check the floor boards and replace the carpet . My youngest son is excited about getting to ride in it with the top off . I came home today and started trying to get an idea of what pieces I need to fix the hell hole, I really want to put the car up on the lift but I'm worried about bending the body or something , I have some 6"i-beams that I bought to build a frame table for my son's 36 Chevy, I thought about using them to make a table to put the car on and lift that . I plan on removing the rocker covers tomorrow to inspect underneath. Thanks for your help
Ratrod87   Newbie hoser scammer pics   Sep 9 2019, 08:35 PM
Ratrod87   I removed the carpets in the trunk to check condit...   Sep 9 2019, 08:39 PM
Ratrod87   I removed most of the stuff in the forward trunk a...   Sep 9 2019, 08:43 PM
Ratrod87   I'm trying to figure out how to post more pict...   Sep 9 2019, 08:45 PM
Ratrod87   I'm still trying to learn how this stuff works   Sep 9 2019, 08:50 PM
Minerva's 914   So far look very GOOD. Let's see some pics of ...   Sep 9 2019, 08:53 PM
Ratrod87   So far look very GOOD. Let's see some pics of...   Sep 9 2019, 09:06 PM
jagalyn   Nice looking car... Nice purchase.   Sep 9 2019, 09:18 PM
Ratrod87   Nice looking car... Nice purchase. Thank you, I...   Sep 9 2019, 09:21 PM
SirAndy   I'm trying to figure out how to post more pict...   Sep 9 2019, 09:50 PM
Ratrod87   Here is the spot under the battery   Sep 9 2019, 09:48 PM
Ratrod87   This is on the very bottom of car directly beneath...   Sep 9 2019, 09:52 PM
SirAndy   This is on the very bottom of car directly beneat...   Sep 9 2019, 11:24 PM
gereed75   Bingo...... jackpot!   Sep 9 2019, 09:52 PM
Ratrod87   I believe this would be a side shift transmission....   Sep 9 2019, 09:55 PM
Ratrod87   The forward trunk appears to be rust free. I poked...   Sep 9 2019, 09:57 PM
Ratrod87   Looks like it has a small oil leak. But everything...   Sep 9 2019, 09:59 PM
Ratrod87   The previous owner had this 2.0 bus motor built an...   Sep 9 2019, 10:07 PM
Ratrod87   Every project I had ever built has had some form o...   Sep 9 2019, 10:10 PM
Ratrod87   The car came with a pile of Haynes manuals and sev...   Sep 9 2019, 10:15 PM
Ratrod87   The rubber bumper pads are starting to crack a lit...   Sep 9 2019, 10:18 PM
Mikey914   The rubber bumper pads are starting to crack a li...   Sep 10 2019, 03:27 AM
AZBanks   The rubber bumper pads are starting to crack a l...   Sep 11 2019, 08:29 AM
Ratrod87   [quote name='Mikey914' post='2745762' date='Sep 1...   Sep 11 2019, 08:51 AM
SirAndy   This should be mandatory reading for anyone: http:...   Sep 9 2019, 11:26 PM
porschetub   As mentioned don't lift on there,clean car but...   Sep 10 2019, 12:40 AM
Cairo94507   Looks like a pretty clean 914 you got there. Nice...   Sep 10 2019, 05:39 AM
BeatNavy   Car looks surprisingly clean except for that jack ...   Sep 10 2019, 05:54 AM
76-914   Welcome to the madness. :beer2:   Sep 10 2019, 06:17 AM
ClayPerrine   :wttc: You have a great starting point. Most pe...   Sep 10 2019, 07:55 AM
Ratrod87   :wttc: You have a great starting point. Most p...   Sep 10 2019, 08:04 AM
ClayPerrine   :wttc: You have a great starting point. Most ...   Sep 10 2019, 08:31 AM
rhodyguy   If your son had to pay for the flared look (and al...   Sep 10 2019, 09:04 AM
dr914@autoatlanta.com   yes the car looks very good, too good to be abused...   Sep 10 2019, 09:21 AM
FlacaProductions   You found some nearly antique parts catalogs, too ...   Sep 10 2019, 09:48 AM
Larmo63   Fix the rusted out longitudinal, get the transmiss...   Sep 10 2019, 10:21 AM
Tdskip   Fix the rusted out longitudinal, get the transmis...   Sep 10 2019, 10:26 AM
Ratrod87   Fix the rusted out longitudinal, get the transmis...   Sep 10 2019, 12:33 PM
Bartlett 914   Fix the rusted out longitudinal, get the transmis...   Sep 10 2019, 02:26 PM
Garland   I noticed this in your post, that’s a good two ...   Sep 10 2019, 10:34 AM
Ratrod87   I noticed this in your post, that’s a good two...   Sep 10 2019, 12:34 PM
Rob-O   I think all of the above is sound advice. I love ...   Sep 10 2019, 07:13 PM
Ratrod87   I think all of the above is sound advice. I love...   Sep 10 2019, 09:34 PM
Larmo63   Try looking here at some threads on 914s that peop...   Sep 10 2019, 09:58 PM
- Lo-Fi Version Time is now: 6th November 2026 - 12:23 AM
