> steering wheel, 1974 914 1.8............removal
brcacti
post Sep 10 2019, 12:59 PM
Hello, is there a video or directions how to remove momo steering wheel and stock steering wheel, want to fix blinker and MIGHT put stock wheel back on, which wheel do you all prefer?
post Sep 11 2019, 06:31 AM
914-6 GT in waiting
I was thinking the turn signal replacement is a pita because some of the new ones are not the same as the old part and require some modifications to work.
Valy
post Sep 11 2019, 09:05 AM
QUOTE(mepstein @ Sep 11 2019, 05:31 AM) *
You just need to make sure you buy the one with the correct connector. There are correct matching reproduction available.
But if you need to change the connector then that's PITA.
This is what I used and it fits 100% but also has a wire for an additional/optional electric pump. It also has the tubing for the legacy air pressure but you don't need it if you go electric. In that case just take the tubes off for an easier installation.
https://www2.cip1.com/ProductDetails.asp?Pr...2D953%2D519%2DG
- Lo-Fi Version Time is now: 21st September 2026 - 03:13 PM
