> Spring choice and rear Sway
Literati914
post Sep 10 2019, 08:49 PM
Is there a point where a stiff(er) [than stock] rear spring negates the need for a rear sway bar? I've got a set of #140 welts that I'd been planning to use with or without a rear sway bar for sporty street car handling and probably some A/X.. but would jumping up to say a #180 spring and no sway bar be a better choice (both seem a bit much?).. or would it be better to use a stock rear sway bar and lighter springs?
jcd914
post Sep 11 2019, 03:21 PM
My old auto-x 914
Front: 22mm front T-bars and 19mm front sway bar.
Rear: 160 lbs/inch progressive rear springs,cut to shorten them for the ride height.
Probably 170 lbs/inch spring rate but I never measure the rate.
I never ran a rear sway bar.
Current 914 will have all stock T-bars & springs and stock front & rear sway bars when it gets on the road. After I have it on the road I will look at what I might want to do to the suspension.
Jim
- Lo-Fi Version Time is now: 24th September 2026 - 03:53 AM
