| Gplracer |
Sep 11 2019, 10:09 AM
Newbie ![]() Group: Members Posts: 19 Joined: 8-September 19 From: Evans GA Member No.: 23,442 Region Association: South East States |
After a considerable amount of research it looks like the following three options are my best choices for a 1973 914 1.7L rebuild.
1. Rebuild the engine the with the same displacement. This would require honing out the cylinders and installing new pistons. 2. Rebuild the 1.7 as a 2056. This would require new cylinders, pistons, rods, 2.0 cam and possible matching to make the valves bigger. Then new valves. 3. Buy a 2.0L motor, increase to 2056 by buying new cylinders and new pistons. All of this assumes the heads are not cracked or need repairs. It appears that option 3 would be the best if I can get a 2.0 liter motor cheap. Plus option 3 would allow me to not have to split the case if there are not any issues. My car has been sitting for about 25 years and has around 80,000 miles on it. My dad was the original owner. The buyer never did anything with it. He parked it on a concrete slab with a roof over it and put a cover over it. Opinions and advise? |
| Spoke |
Sep 11 2019, 05:36 PM
Jerry ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 7,432 Joined: 29-October 04 From: Allentown, PA Member No.: 3,031 Region Association: None
3. Buy a 2.0L motor, increase to 2056 by buying new cylinders and new pistons. Opinions and advise? (IMG:style_emoticons/default/agree.gif) I took this route. For $850 I bought a 2L engine from Gerald Shaffer which included dual Weber carbs and Pertronix electronic points.. The plan was to punch it out to 2056. However when I took the heads off I found the pistons were already 96mm. I cleaned the engine up, put it all back together and fired it up. 3 years later it's still running good. |
Gplracer Engine Options Sep 11 2019, 10:09 AM
mepstein There is always some 914 owner selling off there p... Sep 11 2019, 10:26 AM
BeatNavy
There is always some 914 owner selling off there ... Sep 11 2019, 11:14 AM
914werke you forgot the intermediate option: 1.9L or 1911 b... Sep 11 2019, 11:19 AM
Literati914
you forgot a the intermediate option: 1.9L or 191... Sep 11 2019, 12:54 PM
thelogo Do you want to spend the most money
2056 big/4
... Sep 11 2019, 04:32 PM
Superhawk996 I will likely be selling a rebuilt 2.0l by spring.... Sep 11 2019, 04:35 PM
porschetub
I will likely be selling a rebuilt 2.0l by spring... Sep 12 2019, 12:31 AM
Gplracer
3. Buy a 2.0L motor, increase to 2056 by buying... Sep 11 2019, 06:46 PM
[quote name='Spoke' post='2746290' date='Sep 11 2... Sep 11 2019, 07:17 PM
JeffBowlsby None of your options consider fuel delivery. Coul... Sep 11 2019, 07:27 PM
Gplracer
None of your options consider fuel delivery. Cou... Sep 11 2019, 10:10 PM
None of your options consider fuel delivery. Co... Sep 12 2019, 05:32 AM
Gplracer
[quote name='Gplracer' post='2746339' date='Sep 1... Sep 12 2019, 07:30 AM
Superhawk996 :unsure:
Guilty as charged. Sep 12 2019, 04:09 AM![]() ![]() |
Lo-Fi Version | Time is now: 4th October 2026 - 06:47 PM |
