> Engine Options, Picking the right build for my 1.7.
Gplracer
post Sep 11 2019, 10:09 AM
After a considerable amount of research it looks like the following three options are my best choices for a 1973 914 1.7L rebuild.
1. Rebuild the engine the with the same displacement. This would require honing out the cylinders and installing new pistons.
2. Rebuild the 1.7 as a 2056. This would require new cylinders, pistons, rods, 2.0 cam and possible matching to make the valves bigger. Then new valves.
3. Buy a 2.0L motor, increase to 2056 by buying new cylinders and new pistons.
All of this assumes the heads are not cracked or need repairs. It appears that option 3 would be the best if I can get a 2.0 liter motor cheap. Plus option 3 would allow me to not have to split the case if there are not any issues. My car has been sitting for about 25 years and has around 80,000 miles on it. My dad was the original owner. The buyer never did anything with it. He parked it on a concrete slab with a roof over it and put a cover over it.
Opinions and advise?
JeffBowlsby
post Sep 11 2019, 07:27 PM
None of your options consider fuel delivery. Could add cubic $$$ dependent on what method you use.
Gplracer
post Sep 11 2019, 10:10 PM
QUOTE(JeffBowlsby @ Sep 11 2019, 09:27 PM) *
I have a friend who has two 40mm carbs he said I could have.
post Sep 12 2019, 05:32 AM
914-6 GT in waiting
QUOTE(Gplracer @ Sep 12 2019, 12:10 AM) *
A lot of the guys doing engine swaps will include the fuel system since it's not needed on a six conversion. Many are really nice engines. A couple years back I picked up one for a local owner. $1K for a documented 2.0 with everything. Prior owner was swapping to a six. It requires a little patience.
Gplracer
post Sep 12 2019, 07:30 AM
QUOTE(mepstein @ Sep 12 2019, 07:32 AM) *
Thanks! This is a great suggestion. I am sure there will be many other things to work on since the car has sat for 30 years. My brother did see it start about 10 years ago.
- Lo-Fi Version Time is now: 4th October 2026 - 06:46 PM
