> Carb Bellcrank Equation
damnfiknow
post Dec 28 2010, 09:12 PM
Someone, please, the equation for determining the diameter of a bellcrank to be used on a Weber 40 setup. Standard 914 accelerator cable length/throw (full close/full open) and standard Weber 40 butterfly. Also, anyone know of a source for such a bellcrank? Hope not to have to farbricate one myself. No lathe so will have to be with an electric drill for turning power. Extremely primitive.
bbrock
post Sep 13 2019, 06:15 PM
QUOTE(Tbrown4x4 @ Sep 13 2019, 05:28 PM) *
@mikey914 As a side note, I'm testing 914rubber's throttle cable. It needs to be about 4 inches longer to be routed through the tins like OE.
@Tbrown4x4 thanks for this info. So I am clear, this would be about 4 inches longer than stock cable length for OE routing through the tin to connect with CSP linkage? I'm assuming Mark's cable is stock length. Also, this would be 4" longer for both cable and sheath, correct?
damnfiknow   Carb Bellcrank Equation   Dec 28 2010, 09:12 PM
McMark   The absolute best bellcrank I've seen is this ...   Dec 28 2010, 09:17 PM
mrbubblehead   The absolute best bellcrank I've seen is this...   Dec 28 2010, 11:15 PM
ConeDodger   The absolute best bellcrank I've seen is this...   Dec 29 2010, 02:34 PM
anderssj   The absolute best bellcrank I've seen is this...   Dec 29 2010, 02:43 PM
biosurfer1   I have the one Mark pointed out and I like it. It...   Dec 28 2010, 10:01 PM
McMark   I sure do!   Dec 29 2010, 01:10 PM
jeffdon   I sure do! So in this setup, it appears tha...   Dec 29 2010, 01:15 PM
mrbubblehead   [quote name='McMark' post='1411156' date='Dec 29 ...   Dec 29 2010, 02:23 PM
SirAndy   My carbs are absolutly identical, which means the ...   Dec 29 2010, 02:24 PM
mrbubblehead   [quote name='McMark' post='1411156' date='Dec 29 ...   Dec 29 2010, 02:39 PM
mrbubblehead   I sure do! do you think this is a better se...   Dec 29 2010, 01:32 PM
kg6dxn   I sure do! do you think this is a better s...   Dec 29 2010, 02:16 PM
porschetub   I sure do! do you think this is a better s...   Sep 13 2019, 01:22 AM
Cevan   Let me see if I can remember how I did mine. If I...   Dec 29 2010, 03:03 PM
McMark   I have a hunch that it does not pull equally on b...   Dec 29 2010, 03:49 PM
azbill   Take a look at the Sidewinder bell crank designed ...   Dec 29 2010, 05:57 PM
914werke   @mcmark In the example pic you provided it appear...   Sep 12 2019, 05:21 PM
johnhora   Source for the CSP Mark mentioned... https://www2...   Sep 12 2019, 09:53 PM
porschetub   Source for the CSP Mark mentioned... https://www...   Sep 13 2019, 01:29 AM
Tbrown4x4   [quote name='johnhora' post='2746671' date='Sep 1...   Sep 13 2019, 03:02 AM
Chi-town   Type 4 with pancake fan I believe is the applicati...   Sep 13 2019, 09:20 AM
914werke   I bought Mark's bracket and took the cable up...   Sep 13 2019, 09:52 AM
euro911   Wow, old thread. I used the CSP bell crank linkag...   Sep 13 2019, 10:54 AM
Tbrown4x4   I bought Mark's bracket and took the cable u...   Sep 13 2019, 05:28 PM
bbrock   @[url=http://www.914world.com/bbs2/index.php?sh...   Sep 13 2019, 06:15 PM
Tbrown4x4   Yes, 4 inches overall. That left a nice radius fol...   Sep 13 2019, 07:53 PM
porschetub   Currently out of necessity building one from a chi...   Sep 13 2019, 11:24 PM
porschetub   Speedworks (?) have one but its a front mount that...   Sep 14 2019, 11:26 PM
- Lo-Fi Version Time is now: 1st May 2026 - 03:43 AM
